Allis chalmers b tvo
Owen_brassfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Owen_brassfield Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers b tvo
    Posted: 13 Apr 2017 at 10:58am
What is the best mixing ratio for tvo for an allis b
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:11am
I would think that diesel fuel would be reasonably close to TVO. Kerosene might
also be pretty close. Diesel fuel is more "oily" than kerosene.
For us on this side of the pond, it means Tractor Vaporizing Oil.
Back in the early tractor days we had a fuel that we called power fuel
or distillate. It was probably the same as tvo.
 I hope that i haven't just confused the issue some more.
Dean
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:39am
I've heard it called "tractor fuel" as well.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Owen_brassfield Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:49am
Their all just different names for tvo however I want know how to mix your own tvo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 12:07pm
This is taken from Vintage Tractor Engineer:
1 part petrol (gasoline) and 1 part heating oil (furnace oil) results in 59 octane
2 parts petrol and 1 part heating oil results in 72 octane.
He recommends the lower octane for topping and light work
and the higher octane for heavy field work.
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 2:48pm
You dont need to mix T V O just use central heating oil  in it thats all we use in our 20 Allis tractors as long as you keep it hot you will be fine
Edited by everett048 - 13 Apr 2017 at 2:49pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 4:50pm
I must be missing something....what are all these different fuels? I'm used to just starting and running on gasoline, so all this is new to me. I've heard of "distillate" and "tractor fuel", but how is it different from gasoline?
 Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 5:05pm
Creston - its a 1920- 1940 era thing... gasoline was not readily available and $$$.  They were looking for CHEAP.. That's why most of the motors from that era have 5 :1 or 6:1 type compression ratios.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 5:11pm
Distillate was a left over component of petroleum refining in the 1930s. A little lower octane than gasoline with poorer vaporization. Being a left over it was cheaper than gasoline. Takes heat to get it to vaporize hence the heated intake manifolds and the dual fuel systems on tractors made to use it, always had to be started and warmed up on gasoline before switching to distillate. It may have had more btus per gallon to give a bit more engine power despite the lower compression ratio required for the lower octane. Most likely the main benefit was being cheaper than gasoline.
Somewhere I have a 30's vintage book on engine design. It probably comments on fuels like distillate, but I don't know where that book is right now.
Gerald J.
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 5:41pm
There is an old discussion on the YT site titled What exactly is distillate.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 6:12pm
Gentlemen,  I am in WAY OVER MY HEAD.  I had no idea what TVO meant.  When we sold them 30's to 62 we always used gasoline till the diesel's came along.  However, the gasoline right after WWII was pitiful.  Once I could not ignite it with a match.
Thank you so much for explaining in such detail.
Take good care of my favorite.
Good Luck!
Bill Long
