Allis Chalmers B foot brake conversion
SnoJetter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SnoJetter Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B foot brake conversion
    Posted: 17 Aug 2011 at 9:44am
Hi all - I'm in the process of converting my '39 B from hand brakes to foot brakes. I have all the necessary parts to do this except for the two angle iron rails where the fenders mount. I discovered that the rails for the foot brakes have a cutout for the brake rods and also the rings welded where the pedal shaft is supported. I put out a classified ad looking for these parts, but with the size and weight of these things, I suspect they will be pretty expensive to ship. So my question is if an of you are aware of a tractor salvage yard or some individuals in the west central Minnesota area who might have a slavage tractor that I can get these parts from - a person or place within driving distance that I can contact and incquire of parts availability.
Thanks much!
Kyle Sands <>< Alexandria, MN
willys_46@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 10:17am
 I have a set of fender brackets off a C that i will sell. Im located 30 miles south west of Minneapolis. Send me a PM or email me at mbscott881@hotmail.com      Matt
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 4:06pm
 stock C supports and B supports are not a match but C supports can be made to work by cutting them down to the correct height for the 39B fenders with the steel tabs to fit over them at the corrected height. If your going to go to all that trouble you may as well notch the old 39 supports and weld the rings on the end. You will probably want to raise the seat frame too or find a tall one off a foot brake B. There is a little more to converting a handbrake B to a footbrake B than meets the eye.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SnoJetter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:26pm
Ken - thanks for the information.  My plan for a seat was to find a pan seat (presumably aftermarket) rather than stick with the stock bench seat.  A neighbor had a B equipped with a pan seat and it was the slickest little tractor to get off and on.  With the bench seat, it's a pain...and I'm only 34.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:52pm
Wait tiil your 70 like me. Everything I do is a pain
This page was generated in 0.220 seconds.
