Allis chalmers b camshaft resistance |
Tcfcowboy
Topic: Allis chalmers b camshaft resistancePosted: 7 hours 39 minutes ago at 8:03pm |
Hello all, I am working on a total restoration of a 38 model B, I installed new Clevite camshaft bearings, and when I put the camshaft back in, it seem to have a bit of resistance, my question is, should the camshaft spin freely, or is it supposed to have some resistance? Thanks.
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 689 |
Posted: 7 hours 3 minutes ago at 8:39pm |
Cam drives the oil pump, which adds drag. New bearings are snug on cam with break-in lube. Cam takes ~5' pounds to start turning and then less to continue turning. Cam should have no binding during rotations.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8936 |
Posted: 6 hours 53 minutes ago at 8:49pm |
did you swell any driving in? Roll it around some and remove. Look for bright(tight) spots and scrape down.
Les Kerf
Posted: 5 hours 30 minutes ago at 10:12pm |
With nothing else attached (no oil pump, crankshaft, pushrods, etc.) the camshaft should rotate quite freely. I would use light oil for checking, use assembly lube for startup.
Edited by Les Kerf - 5 hours 27 minutes ago at 10:15pm |
