Allis Chalmers 5040 /w 400 loader
lkennett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lkennett Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 5040 /w 400 loader
    Posted: 06 Aug 2025 at 1:27pm
Can anybody identify the pump above the pto on my 5040 Allis?  It is responsible for running the loader. I just picked up this old tractor as a project.  I am told this pump needs a seal because it leaks fluid into the transmission from the loader reservoir and causes the transmission to overflow.   Using an auxiliary pump off the pto shaft for now.  I cant find a part number or markings on the pump to identify it.  Should be an easy fix if it just needs a seal.  Hoping to get the tractor back to usable condition before winter.
  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 2:42pm
Should be the same shaft seal as any other 400 or 500 series loader or Gleaner F or G combines. The pump is a little different to other 400/500 loaders as it turns in the opposite direction. But, I'm sure all internal parts are identical, just the housings are different for bass-ackwards rotation.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:49pm
Pumped used on Fiat built tractors,both my Oliver 1365 tractors with loaders have the same pump.Also used by Fiat built Long tractors.Be very careful  not to damage or lose the drive gear they are about impossible to find.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:53pm
If memory serves, the numbers would be on the mounting face of the pump.
Original pumps were made in Hutchinson, Kansas by Cessna.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:59pm
In 2006, we replaced the original pump with an EATON 26009-LAA.  1.48 CID, 11?16 KYD. 3/4" x 1/2.
This was on a 500 Loader mounted to a D-17. Had to modify mounting bolts & pump guard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lkennett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 10:14pm
Thanks for all the replies on this.  I pulled the pump off tonight and found the part number.   It is a cessna pump, numbers I found were B24307LAQ.  Not sure the significance of the last 3 digits.
I took the calipers out to measure the shaft.  .685" or 17.39mm  so 11/16 and it is keyed.
I am in the process of removing the loader, the tractor needs a clutch which is the first priority.
There are some markings on the seal but hard to make out the full number, so far all I can find are large kits which may exceed the cost of replacing the pump.  I might try and contact one of these companies to see if they can just get me the seal and not a $300 kit.  If a seal does not resolve the problem then I will just do a new pump.  No idea how many GPM this pump was rated for.   Pumps from Princess Auto (canada) are all 3/4" shaft.
In the second picture you can see the seal is half missing, so like the previous owner said it was just dumping fluid from the loader into the transmission.
If people are interested, I will keep this thread going.  Never split one of these old tractors before.    Like I said it needs a clutch, not sure if just a disk or the whole package.  I suspect is going to be really bad.  The loader covers the inspection plate but I know its needs to be split.    I was thinking maybe the loader dumping so much oil into the transmission got onto the clutch?  Maybe wishful thinking.
All the cylinders on the loader are leaking, some of the hoses.  All look ripe.  The dash is dead, I have bench tested the tach and temp gauge, they seem fine.  Tach cable is mia.   The fuel gauge is stuck.
Tomorrow I am building a support to hold the loader as I remove it.
Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 6:42am
Call Surplus Center they have a big selection of pumps and also pretty good tech folks to help.Also very reasonable prices on all things hydraulic.
Jason Bubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason Bubb Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 7:21am
Hey,
I have been trying to find the mounting plate for the pump you are looking for. Would you mind taking pictures for me of the plate? I am trying to make one but I have no pictures besides the black and white ones in the manual book.
Thank you.
Jason bubb
Post Options Post Options   Thanks (0) Thanks(0)   Quote lkennett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 9:44am
Thanks Jason,
The pictures in this thread is what mounts to the tractor.  It is a standard size.  SAE A Two Bolt Flange.
I do have a new pump, same flange just different shaft size.  5/8 instead of 11/16.  I am going to make up a bushing to take up the space.  Just have not done it yet.  The tractor is currently in use moving snow around so it will wait until spring.  There is a PTO mounted pump that works fine it just stops if you push the clutch down all the way, you just learn to work around it.
There was another thread I had started on this tractor.  it needed to be split and clutch work.  All that got done and came out great.
I have a google album I can share if people are interested (not sure if that is against any rules?) that has 100 pictures of the process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 11:43pm
Originally posted by Jason Bubb Jason Bubb wrote:
Hey,
Thank you.
Jason bubb
You are also going to need the drive  gear for the pump they are extremely hard to find
