Allis Chalmers 185 |
PaulSamwel
Topic: Allis Chalmers 185Posted: Yesterday at 7:45pm |
Bought this non running tractor for not much.Got it running(fuel system issues),replaced front and rear tires,replaced oils and filters,installed a block heater,new starter,went through battery cables,repaired short in lighting system,repaired non working gauges.Repaired front axle from loader abuse.Has 1579 hours on a working meter.Used mainly for loader work as rest of tractor shows very little wear.
PaulSamwel
Posted: Yesterday at 7:48pm |
Looks like I can make the pictures larger.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4259 |
Posted: 14 hours 53 minutes ago at 5:22am |
Nice!
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8770 |
Posted: 14 hours 27 minutes ago at 5:48am |
Ya can't go wrong with a 185! Very sweet tractor
Darrel |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8931 |
Posted: 10 hours 55 minutes ago at 9:20am |
My only concern would be gear jumping with full time loader use. Lot of shifting back and forth. All depends on operator. My uncle bought a new 185 back when. Got to run it on a rotary hoe.
PaulSamwel
Posted: 8 hours 7 minutes ago at 12:08pm |
This is my first A/C tractor,this one was built in 1980.Am concerned about that as well from what Iv'e been reading about these tractors.
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 153 |
Posted: 7 hours 53 minutes ago at 12:22pm |
I would say to get used to using the power director before you start using it for hay work (assumption on my part, the tedder is in the background). I use a 190xt mainly, also have a 7000 and a 4430JD. I prefer the 190xt, and I think you will like your 185.
Ted |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5422 |
Posted: 7 hours 50 minutes ago at 12:25pm |
If you got that for cheap that’s a nice one!! They are nice tractors, hopefully the previous owner brought the tractor to a complete stop before shifting. Low hours if they are correct. Rops is a nice option to have.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7623 |
Posted: 4 hours 60 minutes ago at 3:15pm |
Can't see how the front axle would need repair after only 1500 hours of use - even with a loader. Tack could have been replaced, drive cable could have been broken for years (or unhooked). I never trust the hours on these older tractors. The tach on my 175 shows around 5000 hours, but the tach cable was disconnected for 15 years!
