Allis Chalmers 180 engine block drain |
Post Reply |
andyjax
Bronze Level Joined: 12 Apr 2020 Location: Georgia Points: 13 |
Posted: 13 Oct 2020 at 6:27pm |
Hello all-
Trying to find the engine block coolant drain on my '71 180-2800 engine. Manuals are incorrect and say the plug is aft of the fuel filter bit don't have a drain plug there. I have two large threaded plugs forward of the fuel filter on the right side of the engine. One is above and slightly forward of the other. Which one? Thanks. Engine serial number 2D 49275.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
You may have a different series 301 block in there with those plugs , the drain plug is on the starter side, close to the oil pressure sensor, theres a small plug think it's square: and thats the coolant drain
Edited by DougG - 14 Oct 2020 at 4:35am |
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 823 |
As Doug says, starter side. It's between starter and fuel filter, almost hidden behind the fuel primer pump.
MACK
There is one behind injection pump also. MACK
andyjax
Thanks. I'll look today. Really would like to drain and flush the block. I'm re-doing the cooling system and there was some rust in the radiator. Is the plug square then or hex head-don't want to unscrew the wrong one. Also how big is the plug? The ones I mentioned are at least a 3/4" wrench size, maybe bigger.
Orange Level Access Joined: 12 Sep 2009 Points: 19572 |
9/16" wrench...…..1/4" pipe thread drain plug.
andyjax
thanks again. I found three of those on the same level in the block. One in back of the fuel primer pump, one behind the oil sender unit, and one behind the injector pump. Not wanting to take a chance, I pulled the thermostat and old water pump and flushed out best I could. Got quite a bit of 'stuff' out of there but thankfully no rust. Took an air hose with low pressure and forced the rest of the water out. Hope this is OK, if not let me know. I'll put in antifreeze with distilled water before it freezes
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8025 |
The water plug will be slightly higher on block than oil galley plugs. if you remove an oil plug accidentally,just reinstall it.
andyjax
Thanks. One more question while I am talking to the experts- In the winter only, after a cold soaked start, antifreeze is sucked into the crankcase and winds up in the oil. Guess this is a small crack somewhere because it never does it in warm weather. I put some recommended sealer in the antifreeze and it seems to be holding well. Thoughts?
Thoughts aren't very pleasant. You probably have leaking Orings on the bottom of the cylinder sleeves. Antifreeze in the oil is horrible on engine main and rod bearings.
andyjax
Right. Well, I'll keep running it until I can't. Agco parts told me the other day that more and more parts are being discontinued. Sad.
That's a terribly broad statement. All the parts you need for your engine problem are available. After you run it too long with coolant in the oil the crankshaft will be ruined or have a hole in the side of the block.
andyjax
That's the strange thing-no coolant in the oil since warm weather last spring. Oil looks good on the dipstick and level hasn't risen at all since I drained the antifreeze and oil out late last winter. Doesn't even burn oil. I don't need the tractor as much in the winter so maybe I will let it sit until next spring. Thanks for the input.
Oil will always look just fine on the dipstick until it has been run and mixed in with the oil. Antifreeze goes to the bottom of the oil pan. If you let it sit for a few days in the cold, remove the oil drain plug just to the last thread and carefully see if there is any coolant. It will be right there if there is any.
andyjax
Thanks. Can you recommend someone to rebuild the engine when the time comes? Maybe ship it somewhere? Local talent is unavailable and unreliable.
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8827 |
Have an oil analysis. The analysis will tell you what parts are likely worn in the engine and if antifreeze is present in the oil.
Post Reply | |
