Allis Chalmers 160 hydraulics |
Ooga68
Topic: Allis Chalmers 160 hydraulicsPosted: 19 Jan 2020 at 8:58pm |
my 160 lost all operations after changing hydraulic fluid. upon checking I found that the long pickup tube comming from sump to line going to pump has come loose and fell away from block. My question , when I removed the tube it has a plumming check valve on the bottom. In my manual it shows nor says anything about a check valve there , no mention. is this an old farmer fix for bucket not leaking down.
CTuckerNWIL
Posted: 20 Jan 2020 at 5:32pm |
If it is on the pick up side of the hydraulic pump, it is there to keep oil i n the pump so it is primed whenever you start the it. If it isn't there, the pump can drain out and lose prime. |
