allis chalmer plow parts
franklin05457 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote franklin05457 Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmer plow parts
    Posted: 18 Apr 2012 at 8:39pm
I am looking for plow shares and shins for an Allis Chalmer 60 series 4 bottom plow. Shares have 3 bolts holes and shines have 2. Where can I get these ?
Thanks Smile
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 8:13pm
Those parts differ with the bottom number which can be many differant ones on that frame. No matter which bottom you have there is no "go to" place to get the parts. Swap meets, shows, parts dealers on here, auctions with A-C stuff or adapt parts that are still in production. That's the cloices.
Edited by Butch(OH) - 10 May 2012 at 8:13pm
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 8:36pm
The only plow shears that a lot of places have that is AC  is for 387s. That is the trouble about owning a AC plow. It is a shame too .
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 9:30pm
Plow bottoms and frames were sold separately. Different bottoms for different soils. Plow frame is almost no help in identifying the bottoms. A 60 could use bottoms numbered 25 to at least 387 and probably even 392 and everything inbetween.
You need to find a part number on the bottom parts which can be then traced to the plow bottom in the plow bottoms book available at
http://www.grandpastractor.com/phpBB3/index.php and then you can find all the optional plow shares that will fit. Usually there were at least 6 different shares for each bottom and bottom width, of different metals and shaped for different purposes. Some better at wear, some better at standing hitting rocks, and some better at pulling the plow into the ground.
There is a very outside chance that an Agco dealer will have parts by the part number, but they will be priced like silver, if not gold.
It may be much quicker to visit a farm store with a few shares and pick one about the right shape, then adjust its shape with a grinder and drill new holes in the frog so it will stay in place. AC plow bolts are another thing getting very rare and after market shares will probably use more readily available plow bolts.
Gerald J.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2015 at 8:20pm
I have plow shins and lays,NEw and used. Soft center land Throw away. My be able to help on hard to find ones. 785-353-2392 Thanks Rays
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2015 at 7:02am
Check with Davetheplowman who is on this forum.  Has all the A-C plow parts.
