Allis CA Seat Spring and Shock |
ACCA52 ![]() Bronze Level ![]() ![]() Joined: 26 Jul 2021 Location: Grove City PA Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Oct 2021 at 7:41pm |
Wanted to share my findings that may help other big guys. I weight 350lbs and the CA seat spring was just too soft. after experimentation i found Monroe shock 555002, Summit Racing 2.5id 12inch unspring length coil over 110lb spring are a good combination. the original spring caps were too small for the spring so i heavily modified some qa1 aluminum flat spring caps to work, but probably would have been better off making something out of steel. Originally i tried 175lb spring but it was way too stiff, did not compress at all with me in the seat.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5156 |
If you have a CA operators manual, it shows the 2 positions for the stock seat shock/spring mount for light/heavy operators, however I think it is fair to say the 350Lbs is an overload for the stock parts.
Dale (Stonelick) ![]() Bronze Level ![]() ![]() Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 185 |
I installed a Harley shock on my CA. Bought a new pair in the box off CL for $20 - Progressive Suspension 412-4037C 412 Series (Chrome) Harley 11.0". Had to modify the top and bottom mounting bolts a little. Seems to work well for me, but don't weigh that much.
1951 CA - 1944 C - 1949 B - Kubota M6800
