Allis B front mount planter
rellis73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rellis73 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B front mount planter
    Posted: 31 Dec 2011 at 3:58pm
Recently we pulled the planter out of the back of the tractor shed which hasn't been used in probably 40 years.  This planter is the kind where the hoppers and mechanisms mount to the cultivators frames on the left side of the tractor and the layoff plow and planter foot attaches between the cultivator frames underneath the tractor.  We did find all the pieces but the flat link drive chain is pretty rusted, stretched, and generally worn out.  I'm not sure how to measure this to tell you what pitch the chain is.  The best I can do is tell you that the opening where the tooth of the sprocket rolls into is about 3/4" lengthwise.  Does anyone know where I can find this chain, it really needs replacing?  We are having problems getting the main drive from the sprocket on the rear wheels to the planter to stay on.   Trying to get this ready for the spring planting.  We are going to leave the mule planter in the shed this year and plant our sorghum, for making molasses, with the Allis B.
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 6:04pm
If you go to dlchain.com , go to catalog ,and down to steel detachable chain there is a chart with dimentions.  Tractor Supply lists it in there catalog, there is also farmchain.com.  Sounds like a neat project.  Where are you located?  Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 8:57pm
Sorry to horn in Don, but I found that it is farmchains.com  You forgot the 's'
Post Options Post Options   Thanks (0) Thanks(0)   Quote rellis73 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 9:11pm
Thanks!!!  We had always called them planter chains and even Google couldn't find anything on that one!!  :)
I'm in Lincolnton which is just about 45 minutes west of Charlotte.  Hopefully when I get it together I can get a few pictures of the setup posted.  I have noticed there are not many posts here or anywhere for that matter on this planter setup.
This page was generated in 0.029 seconds.
