allis b 3rd gear
playsindirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote playsindirt Quote  Post ReplyReply Direct Link To This Post Topic: allis b 3rd gear
    Posted: 17 Jan 2012 at 5:30pm
I have a b that pops out of 3rd gear.It doesnt do it all the time but would like to fix. Hard to do?
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 7:02pm
With my very limited knowledge, I think it has something to do with your clutch. If you tightened it or your forks may need work. Just my thoughts.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 7:25pm
i dont know much about b's but im pretty sure they have a sliding gear transmisson, which means.... your shifter is worn and your not fully engaging 3rd gear or your gears are rounded and disengaging or maby the detent ball and/or spring fell out or is worn.
if a b is similiar to a wd, you can remove the shifter and weld it then reinstall, not too bad.  worn gears, pulling tranny.   i dont know where the detent is as i dont have a b.  good luck
