Allis Air Champ 78 help needed |
david.bz ![]() Bronze Level ![]() ![]() Joined: 26 Dec 2011 Location: Belize C.A. Points: 33 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Dec 2011 at 10:02am |
Hi there. I converted a 78 air champ from the the electric motors to a single blower. How much cfm or psi air pressure do i need to have in the planting chamber to have the correct pressure?
Thanks. |
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3526 |
good move - I did this and had exceptional results. Just like the White planter run 1.5 - 2.5 WC " of pressure. That is WATER COLUMN INCHES of pressure. Invest in a good gauge like the White planters run. I also chaged to the SHORT cut off pad and installed "tickler" brushes from a white planter and the resluting seed spacing was as close to perfect as possible. To find the correct air pressure run at planting speed and stop as fast a possible - IF one has skips, the increase the air pressure, IF one has doubles decrease the air pressure - IF all pockets are full and no doubles -PLANT - check the small drive chain - if it has rusted links it will pop the seed disc ratchet style. The seed disc size is also important. The seed disc starting with 715xxxxx is the one we used the most. I had rather have a disc I thought was too small and increase the air pressure than use a disc too large. IF AC had a common air system as in the White unit - they would have sold a lot more units. While at it - the addition of "runners" or strips of metal running right beside the double disc operners attached at the front and floating to the rear prevents soil blow out. Look at the strips Sunflower Drills use - a definate must for good seed placement. Prevents the double disc operners from throwing soil out of seed trench. Also the scraper between the openers is important. We welded a 1/4" key stock where the worn scaper edges were. These additions will make this unit plant with any modern unit.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8716 |
tbran, your info is very beneficial to me as well. Been thinking about getting rid of the electric fans for a common system also. Where would a person get the water column gauge from; is a white dealer the only source? Also wondering about the tickler brushes, where do they go? You really got me interested in checking out the runners that you speak of also, because my planter is leaving a trench now that is driving me nuts trying to figure out how to prevent that. I've been looking at caseIH planters and thinking about adopting their double disc furrow closer, but I will take a look at a sunflower drill instead for now. Thanks, Darrel
tbran, a super big thank you for your information! I constructed a 3" sched. 80 pvc pipe with 2 1/2" T's at every planter unit. Your idea about measuring the water column is just perfect for my application because I will just insert the gauge into my main 3" pvc pipe. That way I can monitor it while I am planting. Enjoy your evening.
Wes (VA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
I guess this would/could also apply to a 77unit as well? I'm like Darrell, tell me more! we're dribbling seed in a couple rows..
Edited by Wes (VA) - 26 Dec 2011 at 8:22pm |
skipwelte ![]() Orange Level ![]() Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Everything applies to a 77 unit, but the scraper between the discs doesnt float as the 78 scraper does, so its not nearly as effective in damp soil. Good luck Wes,
Make the gauge with clear plastic hose and water and a yard stick. MACK
Hi there. I think that the hose is a great idea. 1/8" npt pvc male with a plastic hose glued inside BUT i am not sure what to use as a breather at the top and to keep the water from running out the bottom? Maybe a breather from a small pickup truck diff. would work on top? Not sure about the bottom.The hose would only need to be like 3" long or tall with " markings on it. Thanks for the idea. I will work on it today.
CHECK DWYER ON INTERNET - GOOD PRICES - SMALL AND LARGE ONES AVAILABLE
michaelwis ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Wi Points: 8765 |
IS THis the planter made before the 385 ?.. i,m hot on the trail for one .. and know next to nothing about it ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
rw ![]() Silver Level ![]() Joined: 28 Oct 2009 Location: United States Points: 384 |
I would love to see some pictures of the outside scrapers you made. I have seen the ones on the Sunflower and tried to figure out how I could do something like that for My 78 units. And how do you adjust the air pressure and what kind of fan did you adapt.Thankks RW
Michael, the Allis Planters with model 78 units were made prior to the 385, which was designed by allis to follow up the 78's, but then Deutz took over and the 385 was then manufactured by I think Vermeer for Deutz. I guess for the most part, the 385 is probably a better planter, but I am happy with my Allis with the 78 units, however I've made modifications to it and have more mods planned for it if I keep it. Darrel
