Allis 7000 |
Empirestate
Topic: Allis 7000Posted: 16 Feb 2026 at 5:56pm |
hello all,
New member here. Been a lurker for a while and have gleaned a lot of useful information. Now I have a problem I could use some help. 1978 Allis,7000. It does not have differential lock, but all of a sudden it acts like it does. Just driving tractor only it steers, but with a round bale on the 3 pt. You can't turn it, not even using the breaks. I suspect something is wrong in the final drive, but what? Thanks for any help Bob
Posted: 16 Feb 2026 at 6:18pm |
The differential is locked up. There is a dipstick directly behind the cab under the SMV sign. I'm guessing your PTO seals have been leaking oil and that compartment is very low on oil. Wheels have to come off. Axles get pressed out of their tubes. Brakes/brake housings come off. Lift arm housing comes off next. Then, you are down to the differential with the ring gear. Cab might have to be lifted a little, but not removed.
Empirestate
Posted: Yesterday at 4:56am |
thanks Dr.,
Are we talking major damage or parts not sliding as they should? I did pull the dipstick, it was low but Still showed oil on the stick. Thanks again, Bob
Empirestate
Posted: Yesterday at 5:05am |
dr. Allis,
I should have asked am I going to do more damage if I were to keep using it? I still have to feed cows Until the weather improves, also don' t have heated shop.
Posted: Yesterday at 6:28am |
More damage?? Maybe and maybe not really. The affected parts are already junk. If you must continue to use it, overfill it 2 or 3 gallons from the top mark on the stick. Maybe even overfill with diesel fuel to act like penetrating oil inside the differential. It will not hurt doing this.
Empirestate
Posted: Yesterday at 6:32am |
thanks dr.
Won't use more than I have to . What am I looking at for ruined parts.
Posted: Yesterday at 7:38am |
Four seized pinion gears inside the differential case and a ruined cross at a minimum. I only remember having to repair one over the years and it had 6K+ hrs on it and had done a fair amount of plowing in its iifetime.
Mikez
Posted: Yesterday at 7:43am |
Welcome to the forum. Goodluck.
Where abouts are you located
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2471 |
Posted: Yesterday at 8:21am |
This is the differential carrier from an 8030 a few years back.
Posted: Yesterday at 8:23am |
That's pretty cool, Lynn. For sure when he placed it in "park" on a hill it rolled another couple of feet !!!
Les Kerf
Posted: Yesterday at 8:26am |
Yikes!
Empirestate
Posted: Yesterday at 3:30pm |
thanks again DR., i'll post back in several weeks when I get it apart. When weather allows. I'll try to use a different tractor if it will pick them. Mike , I'm in the southern finger lakes area.
Empirestate
Posted: 22 hours 26 minutes ago at 5:43pm |
Dr.,
Been looking at the service manual and it talks about splitting tractor. Where does the differential assembly come out? Thru the rear 3 pt. Lift housing opening or thru the front which would mean a split. Thanks, Bob. Just trying to get a handle on what I have to do and plan for.
DougG
Posted: 21 hours 35 minutes ago at 6:34pm |
Not sure of your mechanic skills- but maybe better off getting the complete rear off a parts tractor,,
Lynn Marshall
Posted: 19 hours 3 minutes ago at 9:06pm |
No split required for taking the differential assembly out. Do as the Dr. says and roll it out the back, lift housing area.
Mikez
Posted: 17 hours 5 minutes ago at 11:04pm |
Oh ok other side of state. We’re next to Hudson River
Empirestate
Posted: 12 hours 19 minutes ago at 3:50am |
thanks for the conformation Lynn. Not too far Mike.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8894 |
Posted: 8 hours 42 minutes ago at 7:27am |
So how does that happen? Not using diff lock when needed and spinning the crap out of one wheel? To low oil too?
Empirestate
Posted: 5 hours 33 minutes ago at 10:36am |
steve, doesn't have differential lock, not spinning the crap out of it, just feeding hay. Slightly low on oil, but still above the low mark on the stick.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2590 |
Posted: 5 hours 1 minutes ago at 11:08am |
I assume you have the same issue while going in reverse?
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Empirestate
Posted: 3 hours 37 minutes ago at 12:32pm |
acdiiesel, yes it doesn't matter which direction. Just gotta face the music and tear into it.
Posted: 11 minutes ago at 3:58pm |
Differentials love to be flooded with oil. Overfull is always better than low on oil. in-furrow moldboard plowing used to be the worst thing for a differential, especially if the land wheel didn't have enough weight/traction. I've fixed a couple of 7030-40's over the years and it's always been due to LOW oil levels. You can have one of those tractors 5 to 8 gallons low on oil and all the hydraulics and steering work just fine. Too many neglected or foggy sight glasses. I always fill to the top glass plus a couple of gallons if it's mine.
