Allis 7000 "very weak reverse gear"? |
TREVMAN ![]() Orange Level ![]() Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Sep 2011 at 10:01pm |
I have found a 7000 for sale with 20.8-34 singles , 60% not cracked, fronts better, tractor is a 6/10. The vendor says it has "a very weak reverse gear". He claims forward gears are working correctly. What could a very weak rear gear possibly mean, and what would it take to repair? My Dad bought a new 7000 in 1976 but I dont remember any trouble with any gears...Thanks in advance, Trev.
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 973 |
Means the reverse idler had the teeth worn back due to 'grinding' while shifting in reverse. Just replaced one last week on a 7000. Was able to do by removing the shift tower and diff cover. Took some ingenuity. This tractor was used on a big round baler and excess grinding caused by impatience. Second thing to observe is the gear on the counter shaft to be certain those teeth aren't ground too much.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21402 |
And on the brown belly models, sometimes the gearshift would actually hit the seat (if the seat was clear ahead) and not fully engage all the way causing what Bill described.
klinemar ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Michigan Points: 8045 |
We had a brown belly 7000 and it would not stay in reverse so we traded it off for a 1086 IH after the AC/Deutz Dealer told us it was going to cost $4500.00 to fix.Boy did we get shafted,the IH Dealer sold our 7000 to a mechanic who worked for another AC/Deutz Dealer and he fixed the 7000 like was described. The 1086 turned out to be the tractor from Hell as we had to put a Torque Amplifier in it and every year when we ground corn to put in the silo we tore the PTO out.I finally traded it off for a good used 8050 and was very happy to see that 1086 go down the road!
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1213 |
My black belly's reverse gear was pretty badly eaten up, but the countershaft and the sliding collar gears were still in good shape. It seems that Allis used a metal that was quite a bit softer on the idler gear than the countershaft and sliding collar. To replace the gear, you will need to take the differential cover off and the shifter tower. Then you will need to drain the oil down in the differential (probably be best to drain it all out, because chances are you will drop the ratchet, socket, bolt, or retaining tab, or some combination of these in the bottom of the differential housing). Then go in through the differential housing, undo a 3/8 bolt that takes a hand half as big as yours to get to (and a few universal joints and extensions) and remove the retaining tab. Now you need to go in through the top of the shifter tower and work the reverse idler shaft back towards the differential until you can get the gear off the shaft. Mine slid very easily, but I have heard that some are not as nice. If it doesn't slide easily, I'm not really sure if you can hit it from the back and knock the shaft forward. If you did this, I'd be worried about getting it slid back without having to do a rear split so you can tap it from the front. If you buy the A&I gear, you will need to take the gear and shaft to a machine shop or if you have a lathe, you can do it yourself, and have them sized to each other for a nice slip fit (a couple thou tolerance between them). Then you can put it all back together, making sure everything is in neutral. When you put it together, I put some sealant around the reverse shaft between the differential and transmission housing. It seems that this could be a place for fluid to transfer. Basically, put a run around the shaft while it's slid out an inch or so, then push it the rest of the way in and maybe spin it back and forth a little.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
Thanks for your replies, that all makes sense. It really is a decent tractor for 35 years old, Ive started with lots worse. Vendor says mostly used for haying, again, that fits. My Dads 7000 was such a handy tractor, great for so many jobs needing power, very manuverable, easy on fuel. He is asking $4000, I think I'll work the transmission deal up and offer $3000. I may need some talking through to get the trans fixed up from you Gentlemen, thanks alot, Trev.
Definitely don't split at the rear without taking out the transmission brake shaft and all 4 of the powershift/trans lube lines (have to take off the powershift valve body and an elbow fitting on the opposite side). I found this out the hard way...and I own the service manual (I just started reading one section too far forward when I did my rear split...). It's a pretty simple split after that, but you definitely don't wanna make the same mistake I made...
Hurst
5800 Hours |
