Allis 200 power director
Romaninmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romaninmi Quote  Post ReplyReply Direct Link To This Post Topic: Allis 200 power director
    Posted: 02 Nov 2015 at 7:22pm
I went and looked at a allis 200 today it has only been used about 20 hrs in the last 3 or 4 yrs sits outside runs like a top trans does not jump out of 3 rd gear but the power director lever will not go into low range my question is this just from sitting around or is is something internal the current owner has very little tractor knowledge only used it for scraping snow and pulling out stuck trucks in his driveway any help on this would be great
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 8:37pm
I will bet it is stuck from setting outside.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 9:31pm
Do you mean the lever won't move into low posion or won't do any thing in low?  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romaninmi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 9:48pm
It will not move to the low position or n position
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2015 at 6:33am
I guess you are pushing down on lever before trying to move it.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romaninmi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2015 at 10:58am
it has the gated lever
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2015 at 12:13pm
Disconnect it at the valve body to see if it's the linkage or the actual valve spool itself.
