Allis 175 diesel perkins 248
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: Allis 175 diesel perkins 248
    Posted: 10 Mar 2022 at 6:25pm
I bought a 175 that had been torn down with the Perkins 248 engine, it needs an overhaul before reassembly. Originally this engine had a straight wall sleeve with no counterbore cut in the deck of the block. My understanding is straight sleeves are available but another machinist has told me to cut counterbores in the deck and use the updated sleeve. What are your thoughts on this any recommendations of a machine shop? Thank you
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 6:41pm
I've never overhauled one of those. I was unaware of the two different sleeves. I'm a tight-wad and would question if it was good enough for the last 40 years, why does the design need to be changed now?  I know of many parent bore blocks (Ford/ New Holland) that get bored oversize and then a thin repair sleeve pressed into the block. The machine shop leaves a step at the very bottom to keep the sleeve from ever moving downwards. Someone else who has done some of these will hopefully lend some advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 7:08pm
I understand what you are saying but the reason for the failure is the thin sleeve above the deck of the block fractured off. After counterbores are cut in a new style sleeve is installed there's a lot more mass for the fire damn
Allis Express
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 10:05pm
I'm sure it is rare, but I have heard of the old style Perkins sleeve without the flange settling in the block. Most of those Perkins 236 and 248's ran forever with a little care.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 10:11pm
Any chance a failure like these is due to constant overheating  ??
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 10:36pm
My 175 had the top part of the sleeve broken on one cylinder. It was the very top part that protruded up above the block and into the head gasket. The newer style sleeves have more thickness in the top area. A machine shop here worked on the block so they would fit. I have put about 2500 hours on it since that time, and so far so good. Oh, also, it takes a different style head gasket with that change.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 10:03am
This may not be important here. There are two types of Perkins engines. Ag and Industrial.
I've been told that there is little parts interchangeability. A-C uses the Industrial version. MF uses the Ag version. Ag has front mounts- Ind has side mounts. Have a 175 with the 248 and a 715B TLB with a 236 and several JCB Perkins 236 powered telahandlers
Edited by Calvin Schmidt - 12 Mar 2022 at 10:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 10:58am
Sounds like a good place for an Allis 433 out of a 6060
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 11:32am
We have done several.  The sleeves for the industrial block 248 236 are NOT finished and have to be honed after installation to fit the pistons correct clearance .  This is a more precise fit as sleeves can distort on installation.  I have heard of counter boring the block and using the MF style sleeve kit - but never experienced it - it would have to be a lot less $ and machine work for me to go this way.   (Doing a little research - the 236 seems to be a better engine per comments - didn't know that either)
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 1:05pm
A fellow had a 175 that had a problem of massive amount of antifreeze come out the exhaust and water in the oil. We took the head off and there was a hole into the water jacket through the thin liner... found no casting of the block inside the water jacket so somebody had it apart before and just put that thin liner back in without any other attempt to re-enforce it.  He sold the tractor to some one else and they took the engine out and had the block bored for a thick sleeve and rebuilt the engine. Last I heard it was still going.
