Allice Chalmers d14 wont start |
Author | |||
salvaterrasgardens ![]() Bronze Level ![]() ![]() Joined: 18 Oct 2015 Location: alburtis Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Oct 2015 at 4:47pm |
I have an allice d 14. Went to start it up and it cranked but will not start. I can smell gas therefore assumed gas wasnt clogged. i removed the bowl and cleaned the screen which tends to be the usual culprit. I changed the spark plugs last year and haven't had a problem with them since. Where should I go from here?
Sponsored Links | |||
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
The usual. Does it have spark? Apparently it is getting gas.
What is the easiest way to visually check if it has a spark?
jkoby ![]() Silver Level ![]() Joined: 26 Aug 2014 Location: New Castle, IN Points: 179 |
Quickest? Lick finger, stick in plug boot, crank engine!
I use a spare plug (or remove one) and hold it against a clean spot of the engine/frame with a good set of pliers (rubber handled) while somebody cranks the engine. |
When was the last it was used? I just have a wd and have not used a d14. Does the d14 have points that could be tarnished or corroded?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54153 |
Yep, check the points with a test light. If light don't light, check switch or wiring.
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 411 |
Ditto on checking for spark. Also check the points. You should be able to check for spark without cranking if you manually move the points. I think if the points are closed and you open them you should get a spark off the wire going to the condenser.
Thanks everyone for the information. I last used it 2 months ago. Was running fine. Im going to check the plugs and get back to everyone with results in the next couple days.
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2034 |
With the gas today, I always start with new gas. Drain the tank and start with new.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
From a post I made last month. Need to make it into a permanent post or a web page.
From a post I made about 7 weeks ago. Anything in the ignitions system can go wrong. From a post I made a couple weeks ago: Sitting a while points sometimes corrode and don't make contact even when the close. Or I've had points on a running engine stop moving because of lack of lubrication on the point pivot. Fact is everything in the ignition system has to be right for it to run and any part can stop it. Points, condenser, coil, wires, ignition switch, distributor advance, rotor, cap and I've had trouble with nearly every one of these some time.
