all crop 66
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: all crop 66
    Posted: 07 Mar 2021 at 9:19pm
just got a all crop 66 engine driven no dents no rust original paint engine driven , very little paint wore off on the in side so i am sure it is very low hours . i put four new impliment tires on it before i brought it  home,    needs both canvases's .   it is seiral number b29443 what year is it ?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 9:25am
I don't know but we need to see pictures of it!
N186364 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N186364 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 5:46pm
According to the serial number list I have it was built in 1954.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 8:44pm
good to know thanks will try to get some pictures of it and the c i brought home with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 10:59pm
i have a few pictures if i could send them to some one to put them on here
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 11:10pm
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 8:36am
     Looks like you have a couple of great pieces of equipment there; clean looking. I like the extra axle on the combine. Dad added one to his 60 combine and greatly improved the ride as I remember. Maybe a dumb question but what is the item with the "knives" lying on the ground?
     You have some great background scenery too. Thanks for the pictures and let us know about your work on those ACs.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 10:03am
I would like to add that wheel set up to my 60 All Crop bagger engine drive combine. I am trying to put as many options on one combine as I can. I just completed the electric start option on the engine.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 7:58pm
Those knives belong under the straw hood for the flail type straw spreader. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 7:08pm
Also in the picture with the straw spreader is a windrow spreader that goes at the top of the bottom draper in front of the cylinder. I never in my 55 years have ever seen one except in a manual or brochure. You have a great find!!! Ryan
Edited by Ryan Renko - 16 Mar 2021 at 7:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2021 at 10:56pm
that was my next question is what that is i could not figure where it mounts what side is the gear box on   and what realy is it supposed to do
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2021 at 11:52am
It mounts toward the top of the header and that "finger" moves back and forth, it spreads windrowed crops out for more even feeding into the cylinder. Gear box mounts on right side of the header. Should be another sprocket already on the combine to drive that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2021 at 10:15pm
i did not see a sprocket but i will look agian ,  do you see the rusty pulleys on the left side of the header  what could they be for?  ihave taken the drive shaft off and i need to clean the carb change the plugs witch still have orange paint on them and the oil filter is still the soup can looking style witch would be neet to find an other one i will save it for parade show day along with the spark plugs  . i am hoping the cylinder tach still works i will give it some tlc before i turn it ,  i have not found a worn bearing on the thrasher and have most taking grease so far  .   were do i find drapers ? the top one looks like it has  about 4inch tines on each bar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 7:52pm
The pulleys on the left side are for a rotary pickup in front. I would like to see a more better picture of this upper draper with 4" tines?? Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 10:39pm
not much left of the upper draper i will put whats left in a pile and take a picture of it .   got  engine running but no oil pressure  gauge works  took oil filter base off cleaned every thing good  blew back threw stem with light compressed air , hope i didnt ruin the corks in the rocker shaft .       then hooked a vacuum pot up and it would draw up oil so i will put a tee in between the gauge and base and hook it to a pressure pot full of oil and start it and see what the gauge does and see if it picks up but i think something is wrong with the sump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2021 at 9:43am
I'm thinking the upper draper you described with the 4" tines is actually the rotary pickup that goes in front so pictures would help. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2021 at 1:32pm
did they have a jack or a stand for the hitch ?
