airesearch TO448 rebuild kit ??’s
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Topic: airesearch TO448 rebuild kit ??’s
    Posted: 19 Jan 2018 at 7:02pm
I have a TO448, having trouble finding a rebuild kit for it. I have found “TO4” rebuild kits I’m not clear if that will work??
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 9:34pm
Take it apart before you buy a kit. Most of them, you cannot get them apart. Bolts twist off, heat shield sticks in exhaust housing, ect. Go buy one already rebuilt.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 10:23pm
I've always wanted to go to a rebuilder and see how they can get them apart......6 twisted off exhaust bolts and then it's still stuck together !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 5:44am
If you are thinking about "rebuilding" because of some looseness in the shaft?? that's the way they are !!!!... they have floating bearings and they are a bit sloppy. If it ain't leaking oil into the intake manifold, it's probably just fine. Been a while on the Air-Research numbers, but I think a TO-4/48 is from a 190XT ??   Any TO-4 "B" series is a better performing turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 9:59am
Yeah it seems loose, to448 is a 190 turbo. What charger should I put on it? I’ll post a short video if it’ll allow me to.
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 11:15am
It won’t allow me to upload a small video off my iPhone
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 12:47pm
If it isn't leaking oil, I'd do nothing. A turbo from a 200 is a B series and works nice on an XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 1:05pm
A “b” series is a TO4B ?
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 4:27pm
Yup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 4:44pm
Do you know what other applications this turbo may have been put on? 7020, 8010?? Or other application IH, JD, Case??
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 5:06pm
A TO-4 48 ??? only on a 190XT and probably a model G Gleaner combine. No other brands. Any "B" series turbo from a 200-7000-7010-7020-8010 M-M2-M3 would work on a 190XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 7:06pm
I will look into that, thanks for the input doc.
99 f-250 7.3 4x4
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 8:49pm
Here is a link from DJ's Tractor Parts (a sponsor of this site) that I think is a good price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 11:12am
If I were to buy brand new, is there a charger that would be better to buy, that would be a better upgrade over stock? I farm with it so I don’t wanna get to carried away
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 12:09pm
Probably most any waste-gated turbo from a 5.9 "B" series Cummins that wasn't rated at over 140 or 150 flywheel HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 1:53pm
Hx 35 😬 LoL
99 f-250 7.3 4x4
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 2:09pm
That looks like a good price to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 2:05am
after doing research, an hx or hy 30 sounds like the charger I need. The cheap china turbos are only $150-$200 on ebay, not the quality I want, so i’ll Look for a good used one.
99 f-250 7.3 4x4
