agco pto
brodersen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodersen Quote  Post ReplyReply Direct Link To This Post Topic: agco pto
    Posted: 15 Dec 2020 at 10:23am
My dt160 pto wants to shut itself off , so to restart it i need toshut switch off and restart it but will kick out again. not always though. what could be the problem wiring or inturnal ?
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 10:44am
Probably a dumb question, but do you have right speed selected and the right pto shaft in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodersen Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 10:52am
yes` it is on 1000 pto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodersen Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 10:54am
i think iot could be the wiring harness, but the shop guy says it could be inside .
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 11:00am
Had a GT series AGCO that did same thing, very frustrating, if there isn't any unusual internal sounds and correct oil amount than I would say it is the pto switch! Switch changed and no problems after. Was told there was problems with original switches and new heavier duty switches were replacement!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 11:24am
Is it getting a good speed reading,  the reason I asked about pto shaft is if the wrong one is in for selected speed it will run briefly then kick out.  There is a sensor that reads the holes in the outer round part of your pto shafts.  I think that it's the one you can see on top in back.  Maybe these wires are bad or sensor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 3:20pm
Aren't electric and computer controls fantastic---NOT Thumbs Down   You'll never have a problem like that with a WD or CA Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 6:52pm
So very true there,,  its just me but , Im in the One Eighty days- some guys worry so much about the tach reading rpm,s - I have learned just listen to the machine , IE, haybine, baler- youll know when its good,
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 7:29pm
The problem is you would need something like 4 WD's to match the HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2020 at 6:01am
That would also take 3 other people off the unemployment line to drive those other 3 WDs. Also look at the compaction problem you wouldn't have with a bunch of 4000 pound tractors instead of  on 20,000+ plus one. compaction was never and issue in the years past, before No-Till. Much like the 3500+ head dairy farms that milk round the clock with immigrant labor that have put the "family farm" out of business.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2020 at 6:34am
The computer on the tractor has to "see" PTO RPM's and it has to match what the engine speed is or it will assume the PTO clutch is slipping and then disengage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodersen Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2020 at 8:04am
sometimes it will work but running graincart it just shuts off ,then need to shut off pto switch and restart and still wont work doesnt run a minute and do it again. now i wonder if it could be the switch.
