Agco 8775, 8785, or RT 95,RT115
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Agco 8775, 8785, or RT 95,RT115
    Posted: 23 Jan 2021 at 8:04am
Seen a 8775 that peaked my interest and if I can pedal my 6080 I will likely make an offer on. Anyone own a 8775 or 8785 or there RT cousins? Folks happy with them.
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 8:47am
Love my 8775. Has the SuSi motor. 32/32 trans. Only thing I would like would be the 8785 (SuSi with turbo) 10 more HP. The SuSi is very economical on fuel!
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 6:05pm
Bought a new 8785 in 1998. Have over 7700 hours on it now. 402 cu in Sisu engine. Been a very dependable tractor no complaints. No major problems. Like the tractor very much. Our mechanic said those engines should run at least 10000 hours before work needed. Transmission trouble free. We're very particular on maintenance. Makes a difference. Their 100% Massey. Lots of folks on here don't like that. Doesn't bother me at all. I have good dealer support. Paint them green and yellow people would think they were a damn good tractor.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 9:14pm
The engines are fine.
Watch the tranny, clutch and brakes.
Have a MF 6180 parked (needs fixed) in the shop right now. It has the same 32 speed trans as what you're looking at, and the clutch has failed at 4000 hours. It's a wet clutch! Mf mechanic says that's normal for a loader tractor. If you don't catch it right away it contaminates the tranny, brakes, and all hydraulics too!   They never are quite the same after this happens as the metal bits cannot be removed...
So how does this tractor shift?
Keep in mind, these hydraulic clutches are non adjustable. If it doesn't shift easy, it won't.... without a teardown.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
This page was generated in 0.305 seconds.
