Acetone on aluminum pistons
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: Acetone on aluminum pistons
    Posted: 05 Feb 2016 at 12:10pm
Just curious ive been told that acetone is pretty aggressive stuff, how does aluminum react to it? Does the ATF mix prevent corrosion of the aluminum?
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2016 at 12:28pm
I used acetone as an industrial solvent for years. It is really nasty stuff to be exposed to. Builds up in your system and the human body just can't process it out well. You need to use the correct protective equipment.   Can't stress that enough.   As to aluminum it will be fine with acetone. From a materials perspective think of it like the alcohol based cleaner they react about the same with materials.   The alcohol based cleaners are safer ro use then acetone but good clean acetone will clean better. I say good clean acetone because in about a week it will adsorbe enough water from the air to make the acetone leave a white haze from the water makes it useless as a cleaner. I would only use it if I had to. Make sure you read the msds sheet and protect yourself.
Edited by Dan73 - 05 Feb 2016 at 12:45pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2016 at 12:35pm
Link to Acetone M S D S sheet ( Material Safety Data Sheet )
Gary
sheethttp://physics.utsa.edu/memslab/MSDS/Acetone.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2016 at 12:43pm
