AC - IB change to 12 volt
bsvbeach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsvbeach Quote  Post ReplyReply Direct Link To This Post Topic: AC - IB change to 12 volt
    Posted: 02 Aug 2011 at 12:00pm
I would like to know what all I need to switch my IB over to 12 volt system.
Thanks
Louis
Louis Vogle
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:06pm
Why would you want to do that?  More trouble than it's worth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:23pm
A 12 volt power supply like generator or alternator, some new light bulbs, a coil that will work with 12 volts, a diode for the alternator so you can shut the engine off when you want to, or an idiot light set up with a key switch ignition to a solenoid to take the place of the diode so you can shut the engine off when you want and a new 12 volt batry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:26pm
With the alternator you will have to replace the light switch and with a generator you might need a voltage regulator(some hide this in the toolbox)and a new light switch.
Edited by CTuckerNWIL - 02 Aug 2011 at 9:26pm
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:26pm
Here is the schematic that has been floating around the web for years.  More to come from others
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsvbeach Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:22pm
Thanks everyone this will help get me started.
Louis
Louis Vogle
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:02am
Lou,
Easy. Purchase a complete 12V conversion system from us at B&B. Give's you all you need to do a pro wiring job and change your IB over to 12V. Drop us a line if interested...  customcircuits@gmail.com   973-632-5596
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 9:49am
You may want a bigger ammeter with the alternator in place of Steve's uninformative voltmeter.
Gerald J.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 11:34am
You guys are too much.  You know everything.
Listen closely to what Steve says.  He is our resident electrical expert here.  He has an IB so I know his kit would work well.
Good Luck!
Bill Long
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:30pm
Years ago I liked to convert 6 volt systems to 12 volt, due to slow cranking, and short battery life.
Now I have a "smart" charger, "battery maintainer" (several brands available) on all of my 6 volt tractors.
I have it on all the time it is not in use. They crank great, and batterys last years.
The problem is self discharge, it hapens to all of them, but with a 6 volt any discharch is enough to cause poor cranking. If you go to 12 volt and don't use it often, it may start better, but you still have self discharge which causes sulfation which causes shorter battery life.
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:33pm
Gerald, Gerald.. I believe that was another Zing again. Sheesh! For a Volkswagon engineer, you sure get touchy bout' that Voltmeter thing... Lighten up.....Nobody says YOU have to switch to a Voltmeter....
Steve@B&B
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 6:11am
You will be a lot more happy staying with the 6 volt and fixing it that it work's ,you will not be happy when you start breaking the starter drives and chewing up ring gears on flywheel .Just my 2 cents of what I see happen's with alot that where changed over on B ,C and CA's.
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 9:58am
My WD was converted to 12 volt before I bought it. It had a pull switch added to make or break voltage to the coil. I removed that switch and am using the original light switch. I removed the resistor and ohmed the terminals to get the right ones. Now I pull the switch out one click to run and the second position will turn on the lights.
The joy is in the journey.
AC "B" and "WD" and "C"
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsvbeach Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 10:59am
Thanks everyone this has give me 2or3 ways to go.
Louis Vogle
This page was generated in 0.410 seconds.
