ac hydrolic not working
ryan kemp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan kemp Quote  Post ReplyReply Direct Link To This Post Topic: ac hydrolic not working
    Posted: 24 Mar 2015 at 8:27pm
hi every one I am new here I went out of my family and started my alice chalmers collection I bought a ca it needs a water pump it is leaking from the pully it has a 3 pt hitch but hydrolics are not working I draind the oil it was realy milkey I replaced with good fluid and still nothing this is my first alice and my family wont help its not green. any way I am trying to learn this tractor but don't understand the hydrolics any help would be great thanks   ps cant find a new pump
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2015 at 8:44pm
PTO must be on for hydraulics to work.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2015 at 8:49pm
Welcome to the forum.
First of all, It's NOT Alice.  It's ALLIS!
Shouldn't be a problem getting a new water pump.  Readily available aftermarket.  Some of the vendors on this site can help as well.
Good luck with it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan kemp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2015 at 8:55pm
sry for the miss spelling on my phone small buttons lol I know about the pto and found water pump thank you for the help just did not know if there was a trick or any hope to repair the pump and wanted to norrow it down to the pump thanks so much for all your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2015 at 9:20pm
It's easier just to replace the pump rather than rebuild it.  Good opportunity to clean and flush out the rad while you have it off as well.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2015 at 7:24am
Water pump = replace.
Hydro pump = rebuild.
Check all mechanical controls and linkages going to the pump.  You may want to loosen a hose going to lift cylinders to see if you have pressure out of the pump.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2015 at 7:25am
It is alot harder to get it off than to rebuild. Unless the rollers are worn out, there is very little expence in rebuilding one.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan kemp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2015 at 8:21am
Thanks mack thats a great idea I will try it when I get off work thank you all for you support
