ac hydrolic not working |
ryan kemp ![]() Bronze Level ![]() Joined: 24 Mar 2015 Location: north carolina Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Mar 2015 at 8:27pm |
hi every one I am new here I went out of my family and started my alice chalmers collection I bought a ca it needs a water pump it is leaking from the pully it has a 3 pt hitch but hydrolics are not working I draind the oil it was realy milkey I replaced with good fluid and still nothing this is my first alice and my family wont help its not green. any way I am trying to learn this tractor but don't understand the hydrolics any help would be great thanks ps cant find a new pump
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1564 |
PTO must be on for hydraulics to work.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
Welcome to the forum.
First of all, It's NOT Alice. It's ALLIS! Shouldn't be a problem getting a new water pump. Readily available aftermarket. Some of the vendors on this site can help as well. Good luck with it! |
sry for the miss spelling on my phone small buttons lol I know about the pto and found water pump thank you for the help just did not know if there was a trick or any hope to repair the pump and wanted to norrow it down to the pump thanks so much for all your help
It's easier just to replace the pump rather than rebuild it. Good opportunity to clean and flush out the rad while you have it off as well.
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Water pump = replace.
Hydro pump = rebuild. Check all mechanical controls and linkages going to the pump. You may want to loosen a hose going to lift cylinders to see if you have pressure out of the pump.
1957 WD45 dad's first AC
It is alot harder to get it off than to rebuild. Unless the rollers are worn out, there is very little expence in rebuilding one. MACK
Thanks mack thats a great idea I will try it when I get off work thank you all for you support
