AC dealer lighted signs
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: AC dealer lighted signs
    Posted: 16 Jul 2012 at 7:19am
I acquired a 3x 12 AC lighted sign a while back. and just dug it out of storage so I can hang it in my new barn. My Question is what voltage did these signs use? I tried is on 110v but only 2 of the 6 foot tubes partially light. any body know anything about these type of signs?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 7:23am
Signs can be any voltage, from 120Vac to typicality 277V.  There should be a tag on the ballast somewhere that tells you what input voltage it is looking for.  It could be that it is a multi voltage ballast, and you will be lucky, or it could be fixed at 277, then you have a little work to do.  Once you know what voltage you are looking for, then we can help you out.  It could also be that the dealer just didn't put new bulbs in for the last few years, since they knew they were closing, and the bulbs are bad, but let's not guess, till we know the input voltage.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 7:33am
I Tried to read the label on the ballast but most of of it is missing and what is left is unreadable. I tried all the tubes in the spot that the 2 would partially light and all 6 tubes light the same so I think they are good. any more suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 7:40am
Welllllllllll?  If I were there, I would try some things, but since it is electricity, I don't think I want to talk you through it over the web.  Can you post some pics of the ballast?
Still in use:
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 7:52am
I hate to say it, but it might be better to have an electrician look at it. I know we're all DIY kinda guys but this might be a case where one wrong move could screw up your sign.
AGCO My Allis Gleaner Company
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 8:08am
Could be a shocking experience..............
1968 D15D,1962 D19D
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 8:12am
I have the same sign and its plugged into a 120V wall outlet.  It needed new bulbs when I got it. Worst case you may need new ballast if new bulbs don't light up.
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 8:19am
You need a new ballest, may be new scokets for blubs and new bulbs. I have had two fixed. lately.The cost arond 300. It will work like new
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 9:21am
My 3x12 works on 110 V also. Scott
NJBizValuations8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NJBizValuations8 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 9:24am
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 3:25pm
I would be rather suprised if it's 277 volt. My guess would be some parts need replacing.
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 3:50pm
Are there starters for the bulbs? You might just need to replace those. That could be a cheap easy fix.
"ALLIS EXPRESS"
Allis Chalmers 1944 B, 1949 B, D14, WC
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 5:08pm
Send it to me and I will fix it. BTW I will need to keep it for an undetermined amount of time.  LOL
The universal answer to all questions is yes, how much do you want to spend?
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 9:40pm
Sounds like a ballast issue but if the bulbs are dark at the ends you could try new bulbs ive seen old bulbs sorta light but never get bright just kinda flicker
