AC D14 W/LOADER |
Post Reply |
RUBYD14
Bronze Level Joined: 22 Nov 2017 Location: Palisade,CO Points: 30 |
Posted: 23 Nov 2017 at 2:11pm |
I Have an issue with rims breaking. I cant find a HD Wheel for my front that can handle the weight of a full bucket. Any Ideas lug pattern 5 on 5 16" rim my tires are 7.50/r16.
I cant get a image to upload.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21465 |
are you turning the wheels standing still ? friend's D-14 blew BOTH rims off from NOT moving while turning... do it standing still with a load and man that's a LOT of stress so someting has to give. If you have power steering ,it's easy to forget about that 'mimor' detail. If you can find HD rims(they are made....) have a machine shop make some 'disks' from 1/8" plate, holes to match studs and center then weld onto rim.Ideally on both inside and outside of rim. HAS to be welded to the 'ring' of the rim NOT the original disk.
LaJaMe
Bronze Level Joined: 14 Sep 2014 Location: wisconsin Points: 169 |
We have a loader on a d17 that was breaking out the bolt holes. We had the wheels turned out for more width. Turned the wheels back in and have had no problems since. We use it to load 1000lb round bales.
RUBYD14
thanks for the info. I have not been turning without moving. I have power steering but the pump is out so you cant even if you wanted to. I did just lay new creases for my future peach orchard and going in reverse getting into the next row was tough on the arms but the bucket was empty. The original rim that was on the tractor when i bought it blew out on me. I purchased a new replacement from steiner online and it last 3 days of using the tractor. (blew out when I was moving a pile of dirt. full buckets of dirt and rock.) The loader is a ford loader that a previous owner installed. From teh picture I have seen it is twice the size of a AC loader. Is it possible to run a truck rim as a affordable replacement. will the lug bolt holes be the same. I want HD function this tractor is used not looked at.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50528 |
need to find a wfe, from a I-60 or I-600. I think the wfe from such will bolt right up. Also, I think old Buick rims have the right bolt circle, IIRR...
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5171 |
From what you are trying to do - using another brand loader that is twice the size of an Allis Loader, and moving bucket fulls of dirt and rock - you are lucky just a wheel broke and not an axle spindle. Get stronger rims and an axle WILL be next. Sounds like you need a Track Loader, and not a Farm Tractor. Gary |
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
I think the only full width bucket they put on a D14 was for moving snow. I agree with above, you are going to end up with a pile of scrap metal if you keep pushing a 60 year old tractor that hard. What you need is a D17 for what you are expecting from the 14, and probably a Series 4 as well.
Gary
John The 414 and 415 model loaders with the hydraulic bucket has a 60" bucket. But you get a bucket full of topsoil and you definitely have a lot of weight. I know, I did a lot of it this summer with my D-15 II. Gary |
RUBYD14
can you say that again but define wfe i-60n and i-600 means
what an IRRR is too
RUBYD14
I wish I could upload a photo of this any suggestions
jaybmiller
wfe = Wide Front End
IIRR + If I Recall Rightly I-60 = Industrial D-14/15, a beefer version, stronger frontend 'Milton' here has a 72" bucket( 1/2 yard), lifts 1,000# pumpkins up OK but I wouldn't 'haul' full load of heavy dirt or gravel with it....unless on flat ground. Bumpy land = shocks = busted parts = $$$$$$$$$$ !!!! |
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6126 |
Go to the Forum Help section on this site and there is a discussion thread on posting pictures. Charlie Tucker has posted some good instructions on posting a picture directly to this site. HTH
Gary
This may help, a picture is worth a thousand words.
Link to ebay 'Allis Manual for a Model I-60 Note the Heavy Duty front axle. Gary https://www.ebay.ca/itm/Original-1960-Allis-Chalmers-I-60-Industrial-Tractor-Operators-Manual/252853607410?hash=item3adf3fdbf2:g:2MQAAOSwpP9Y5DU6 |
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
IMO, get a smaller bucket, or don't fill it up all the way. Tearing up rims is a good sign you are over-working the entire steering mechanism.
Eldon (WA)
Orange Level Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I'm pretty sure the I-60/600 has hydrostatic steering, you would also need the pump, tank, steering column....basically the whole front of the tractor less the engine....heck, might as well get an I-60/600...it will probably have the reverser, too!
ALLIS EXPRESS!
This year: |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7204 |
Exactly! If the loader is twice as big as it should be, only put half as much stuff in it. The loader must be sized to the tractor. Not whatever someone had laying around. |
RUBYD14
I feel like something else is going on with the front as only the left rim is breaking the right one is still good. I have broke 2 on left side.
Thank you all for the helpful information I will hopefully get a picture up today. |
jaybmiller
I'd check for bad/loose tierod end, wheel bearings, spindle bearings.
Raise and securely block front of tractor off ground and do the 'wiggle' test on both sides. Compare left(bad) versus right(good). If anything is loose, it should be obvious. Jay |
Post Reply | |
