AC B Sediment bowel #%$* |
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Oct 2012 at 3:20pm |
Just venting , no response required. I have a B with a sediment bowel that I can't get to stop dripping even with the pet cock turned off. I have re-plumbed everything twice and even tightened the packing nut. GERRRR
Terry/EasternIa ![]() Bronze Level ![]() ![]() Joined: 27 Feb 2010 Location: Eastern Ia Points: 94 |
Are you using a cork gasket not rubber on the bowl ?
allischalmerguy ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
Well hopefully is is not leaking because of a crack in it. We were on a tractor ride and a fellow had a leaky one on a Farmall H. It ended up it the line was cracked. Terry is right..Make sure you are using a cork gasket on the bowl. I had a rubber gasket that came on the new sediement bowl unit but it leaked...got a cork gasket and not more leak.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Those pot metal bases can get warped from over tightening the bail and will never quit leaking till you replace it or chuck it in a lathe and re-cut the seat. If it leaks when it's supposed to be shut off, it needs replacing anyway unless there is a chunk of crud in the shut-off.
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
Leaking bowels are always nasty!!!
Thanks guys.
Ted |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
When your tightening the bail on the bowl give the bowl a twist just as it seats.
Dusty
MBwcIll ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: Chapin Ill Points: 175 |
My guess it is a bad metal base. The last D 15 we worked on would not stop leaking after I cleaned out the junk in the bowl. Two new gaskets would not stop it (tried both rubber and cork). I just happen to have a new assembly and put it on and re-using one of the just used gaskets it stopped leaking. Then, I could see the original metal base was out of round.
Solved the problem. In my set up the sediment bowel screws in to a male/female nipple (typical for AC B) and the nipple screws into the tank. The sediment bowel that I have has about 3/8 in extension above the threads which if screwing directly into the tank would stick up into the tank to keep dirt out. This extension which is part of the cast sediment bowel was bottoming out into the nipple and not allowing the threads to seal. Solution was to cut off this extension. Now it screws in tight and does not leak.
Way to go Ted. It is sure a good feeling when you fix it and it is fixed!
Pastor Mike |
TREVMAN ![]() Orange Level ![]() Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
The glass on my gleaner E leaked, new cork, new rubber, didnt matter. Last week I took the bail off, turned it 180, tightened it a little by hand, no more leak. 3 years of leaking, tightening with a plier, swearing, head scratching, and fixed in 30 seconds by flipping the bail! go figure, Trev.
