AC B 12 volt conversion kit |
Qvist
Joined: 08 Feb 2021 Location: Harper's Ferry Points: 3 |
Topic: AC B 12 volt conversion kitPosted: 08 Feb 2021 at 1:40pm |
Does anyone know where to get a 12 volt conversion kit and wiring harness for the 10si 3 wire alternator? ,I already have the alternator, alternator bracket and ignition coil. Tractor needs new harness with lights but I am unable to find a three wire version. Thank You
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5191 |
Posted: 08 Feb 2021 at 2:26pm |
For anything electrical the only place I go it the Brillman co. www.brillman.com Or you could call 1-888-274-5562 An tell them exactly what you need and they will make it specially for you with the wires you need for the alternator.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24882 |
Posted: 08 Feb 2021 at 3:52pm |
Steve at B&B would be a real good place to go......
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8625 |
Posted: 08 Feb 2021 at 4:01pm |
I would vote for Steve at B&B also!
Regards, Chris
Joined: 11 Sep 2009 Location: illinois Points: 89156 |
Posted: 08 Feb 2021 at 4:11pm |
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1051 |
Posted: 08 Feb 2021 at 4:25pm |
Yep, Steve at B&B actually makes a little converter harness that snaps right into the alternator and then snaps into your wiring. He's helped me a ton and it's worth the money!
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Qvist
Posted: 08 Feb 2021 at 8:15pm |
Thank you, I will check with these suppliers.
