AC 80R Sickle Bar Cross bar bearing
nichol1122 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nichol1122 Quote  Post ReplyReply Direct Link To This Post Topic: AC 80R Sickle Bar Cross bar bearing
    Posted: 28 May 2022 at 4:12pm
Any idea where to find a replacement cross bar bearing for an 80R sickle bar?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 4:29pm
Do you have a early or late mower. Do you have caps with grease fittings
Welcome to the forum
Edited by Mikez - 28 May 2022 at 4:32pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 10:23pm
Take it to your local auto parts store. They can match the number.                 MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 11:36pm
Those bearing are used in airplanes. I have ordered them before. I can't remember the place but I think it was in California. HTH Tracy
RMD View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 12:30pm
They are KP-A series airplane control bearings.  Two different sizes were used on the mowers - check your dimensions against this site:
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 12:59pm
We have most of those mower parts in stock. But will need to know if you have early or late mower like Mike mentioned.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote nichol1122 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 8:53am
I don’t need the bearings I am in need of the cross bar bushing.
I’m having a hard time uploading the pictures
Thanks
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 9:48am
Try this guy in Iowa, can't remember his name but I have his number 641-572-0194, I restored a model 77 rake I needed a bunch of parts, he had them all and was very helpful and knowledgeable. He parts out a lot of equipment so he may have what you need or a good idea what to replace it with. Good guy
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 10:00am
do mean the knife head bushing with knotches on one end ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nichol1122 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 12:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote nichol1122 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 12:07pm
I’m needing the center bushing with the bolt. The bushing is grooved on the bottom side to fit into the knife head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 6:22pm
That is 803760 for the smooth
And 804518 for the serrated style
The bolt is 920704
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 9:05pm
New old stock grooved bushing. $55. new bushing to knifehead bolt also in stock
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote nichol1122 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 9:21am
I’ll take it! I can mail you a check or pay with PayPal. Let me know what I owe.
Thanks!
Sam Scott
1046 Schaufelberger Blvd
Greenville, Illinois 62246
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 9:36am
I sent you a private message with the details
Thanks!
Sam Scott
www.awtractor.com
