AC 715B - tie rod ends - and steering ?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: AC 715B - tie rod ends - and steering ?
    Posted: 10 Jan 2025 at 11:05pm
Need to replace tie rod ends - anyone have a interchange for the parts or a stock number
Also steering seems to wander , and as you correct it the steering wheel will eventually make a full turn just to keep going straight when roading machine .
 Have always thought it was in the steering control hydraulic steering sector , but know wonder if it's the actual steering hydraulic cylinder has internal leakage which causes the wander of machine .
 No problem at slow speed or when working machine turns fine and has power to turn wheels in sand, mud or such . Just this having to constantly correct when on road
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 8:49am
AC 715 Tie Rod Ends P/N's as follows:
Number  Qty.    Description
1007069  1 Rod End, Tie (Left Hand Thread)
1007070   1 Rod End, Tie (Right Hand Thread)
Source - AC 715 Loader Backhoe Parts Catalog Form 9003463 12/75.  Note this manual is an early manual so when the AC 715B came along - am wondering if there were any rolling engineering changes that would have been covered by a supplement.
U.S. Manufacturers - Moog and Delphi Technology's - possibly Minn Parr
HTH's ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 1:16pm
PDF file for the 714 / 715  AC Industrial - CDS parts list
Now just have to figure out how to convert numbers to industry suppliers
https://www.tractorparts.com/PDFs/AC_710C_714C_715C_SN3301-7217_PARTS.PDF
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 3:40pm
You might try surplus center, looks like they have quite a variety, from 3/4" down...
Edited by DiyDave - 11 Jan 2025 at 3:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 11:28pm
Dave - those are all rod end bearings , the ones used on this tie rod are automotive type and about 1" diameter threads . the stud is a tapered machined surface that wedges into spindle housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2025 at 7:54am
Coke... if the get a couple dimensions, you might match up here..
Edited by steve(ill) - 12 Jan 2025 at 7:58am
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 9:00pm
If anyone finds the correct ends I would Iike a part number, and if anyone sources new kingpins and bushings I really need to rebuild my hubs.
This page was generated in 0.152 seconds.
