AC 7060 pto shaft question
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: AC 7060 pto shaft question
    Posted: 29 May 2012 at 7:28pm
I was hooking up my 535 baler and when i turned on the pto i noticed that there was an unusual wooble in the rotation and when i took it off to inspect i noticed that two of the bolts that hold the reversible 540/1000 shaft where broke off and the others where lose so i replaced the broken ones and Tietend the others but it still had a wooble. is the shaft it self bent ? I inspected it but i really cant tell. Or is there a more serious internal problem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 9:02pm
If it isn't leaking oil, there's probably nothing wrong......other than a bent 540 shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 9:07pm
Thanks i appreciate the reply
