ac 7060 powershift question
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: ac 7060 powershift question
    Posted: 06 Jun 2012 at 9:30pm
My powershift leaver is not exactly right. like when your in 5th the leaver is in between 4th and 5th. And when your in 6th or 5th and you put the clutch in and when it goes back to forth it gets caught like in between if you know what i mean and i have to manually put it in forth..it dont slip or anything and pulls fine any thoughts?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 9:44pm
Adjust the cable at valve to get lever in line with #. After adjusting cable make sure it will still go into reverse and 6th. Loosen the 2 top rear bolts on valve and slide kick out to go to 4th when clutch is down.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 9:51pm
I thought it was an adjustment problem thanks for your info
