AC 7040 |
combine pilot ![]() Bronze Level ![]() ![]() Joined: 21 Aug 2010 Location: sherwood park Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2010 at 7:27am |
I have a AC 7040.I am having problems with the Power stering, it always pulls hard to one side. I have tryed bleediing the system and replacing filters. Has anyone had this problem befpore? if so what do I need to fix it? |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21854 |
If the steering "effort" is higher when turning to the right, I'd guess the flow divider/priority spool is stuck in the power steering pump OR the steering pump itself has some internal issues. I assume all other hydraulic functions work correctly?? and I also assume the front spindles have been thoroughly greased??
Yes, the front spindles have been greased thoroughly. All other hydraulics work perfect. I will give the diverter/priority spool a look. What it does is turns to the right (if you let go of the steering)and hard (nearly impossible)to get it back straight. Was a real challenge to drive it 4 miles down the rode to get it home from the feild. Thanks for the advise. |
