AC 7000 Cold Start |
Post Reply |
Yunggun4
Bronze Level Joined: 19 Nov 2018 Location: Niles Michigan Points: 8 |
Posted: 05 Dec 2018 at 3:05pm |
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 963 |
I hate when this happens.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7204 |
A prime example of how to kill your starter and put excessive wear and tear on your engine! Use the manifold heater for a minute and she will start very easy in 30 degree temperatures. Less than that, plug it in.
Play Farmer
Orange Level Joined: 13 Jan 2016 Location: NNY Points: 732 |
If it's even a little bit cold I plug mine in. If it's plugged in it starts at -20F like it does in the summer. No need to fight it.
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 943 |
He didn't have to put his foot on the clutch to start it?
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Geesh that's crazy ! Painful to watch too,, some heat would meke her pop off , id like to find a decent 7000 ,,
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
What I watched was in slow motion so maybe it wasn't as painful as it seemed.
Wink I am a Russian Bot |
DougG
Me too but got a feeling it was
Lonn
Here's my cold start (w/manifold heater) of the 200 in normal time and no I don't
usually start it this way even at 27˚F but just because I could and
because it is mine I did.
[TUBE]EPwZPn2rtgs[/TUBE]
DougG
AWE WOW ! That engine sounds sweet ! Nice start up for sure, luv those 301,s , shes turned up a little huh?
Edited by DougG - 06 Dec 2018 at 3:16pm |
Lonn
I have no idea if it's turned up. I've only owned it for a couple years. Had high side Power Director redone soon after I got it. Needs the lift cylinders sealed and the hydraulic valves too due to external leaks. The 3-point also drifts down fairly quick so another reason for resealing things up. Now I feel like I've hijacked the original post. Sorry Yunggun. Edited by Lonn - 08 Dec 2018 at 6:07pm |
Play Farmer
From the factory, yes. With the safety switch jumped out, no. Mine has a jumper wire in it. |
Post Reply | |
