Ac 190. Zenith carb work on Jd 3020?
Jk chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Topic: Ac 190. Zenith carb work on Jd 3020?
    Posted: 06 Jul 2018 at 7:34pm
Ac190 zenith carb fitting on a Jd 3020.....??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2018 at 7:35pm
Also what’s a good price for a 190 zenith carb that’s off a working tractor?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2018 at 9:01pm
Deere used a Zenith carburetor on 3020 and 4020 sometimes. I have a collection of service bulletins and one says if you can't tune the Marvel Schebler, replace it with a Zenith. The die cast M-S  used a vacuum diaphragm to operate the acceleration pump and that diaphragm tends to fail and not be included in the carb repair kit. Shoup http://www.shoupparts.com sells Zenith carbs for 3020 and 4020, and likely many other tractor parts places. They weren't cheap at Shoup the last time I looked. My gas 4020 has a Zenith carb.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:31am
Zenith carb from a 190 is different than a 190XT. Neither one will bolt on to a Deere 3020 and work as they are configured.
