AC 160 Steering Seals/Parts
dlow8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlow8 Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 Steering Seals/Parts
    Posted: 01 Mar 2012 at 3:38pm
Hi guys, I have a quick question. I have an AC 160 that I need some steering parts. The Power steering pump started leaking  a while back. I took it off and noticed that it leaking around the front shaft (right before the pully) I assume this is a seal leak, but I'm unsure of what kind/size/type and/or where to order the seals. Can you guys point me in the right direction. I am also in need of the cap that goes on top of the Power steering Reservoir. Anyhelp will be appreciated. Thanks.
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 3:58pm
Go to agcopartsbook.com look up your model i thint under agco -allis that is where i found mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlow8 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 12:32am
Thank you. I will check now
