AC 1300 Field Cultivator Sweep Size |
dnel45
Joined: 13 Oct 2009 Location: Northwest Ohio Points: 164 |
Topic: AC 1300 Field Cultivator Sweep SizePosted: 15 Mar 2013 at 1:02pm |
What was the standard sweep size on the 1300 field cultivators? I have a 24' that I am going to be replacing the sweeps on. Were they all the same sweep size, front to back? Shoup has an 8" sweep for $7.00 / ea. Is this a pretty standard price? Thanks
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 15 Mar 2013 at 1:03pm |
Yes they were all the same size.
IG
llreckow
Joined: 06 Mar 2012 Location: St James Mn Points: 21 |
Posted: 15 Mar 2013 at 1:15pm |
When the 1300 fld cult was new the recommend sweep size was a four inch sweep,all the sweeps were the same size.
dnel45
Posted: 15 Mar 2013 at 1:21pm |
Thanks for the info. Would an 8" be okay on it? Heavy clay ground mostly but usually use field cultivator for light shallow tillage before planting. |
auctioneer
Joined: 02 Mar 2011 Location: Lachine MI Points: 139 |
Posted: 15 Mar 2013 at 1:28pm |
we sell a lot 7 inch the main thing make sure they are 54 degress
dnel45
Posted: 15 Mar 2013 at 1:45pm |
Alright thanks for the info. What do you guys sell them for per shovel? |
auctioneer
Posted: 15 Mar 2013 at 3:24pm |
$ 7.90 for a seven inch
$ 7.60 for 6 inch |
Gerald J.
Posted: 15 Mar 2013 at 3:40pm |
To kill weeds I think they need to overlap. To stir dirt narrower will work, but when I tilled, I had spring weeds like wild mustard that I expected the field cultivator to cut off. And grass in some places where disking only seemed to encourage the grass to grow better.
I bought some from Shoup (www.shoupparts.com) that were only sharp on 2" of the front edge, they didn't cut weeds with the wings until I ground on them for a day. Shoup generally has good prices on sweeps, though one year the local IH dealer beat them considerably. Gerald J. |
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2231 |
Posted: 15 Mar 2013 at 6:13pm |
If you have heavy vegitation, the 1300 will choke up pretty quick, the wider the sweep the more it will clog up. On that model I would go as small as possible with the sweeps and still get weed kill. We had one and used it mainly for incorporating chemicals. It didn't like many weeds..
Leon B MO
Amos
Posted: 15 Mar 2013 at 7:48pm |
I have bought a couple sets from Shoup for my 1300 over the years. I also used the Case IH earth metal ones for their cultivator that are 7 1/4" wide with good results, just theirs is a different angle and the Shoup one's we felt worked better. We did have to shallow the depth adjustment after switching to the Shoup ones. Shoup sweeps are 8".
Posted: 15 Mar 2013 at 7:55pm |
Had a customer buy a set of 7 inch sweeps many years ago against my advice. He did 5 acres and came back and bought another complete set, only this time 4 inches wide. Untilled soybean ground will plug quickly with 6 or 7 inch sweeps. |
llreckow
Posted: 16 Mar 2013 at 1:12pm |
The spacing on your cult should be 6" between shanks,if you go wider than 6" sweeps
you will be just overlapping the sweeps. |
Gerald J.
Posted: 16 Mar 2013 at 2:23pm |
And if you don't overlap weeds will slip through.
Gerald J. |
Amos
Posted: 16 Mar 2013 at 8:41pm |
I forgot to mention, the larger sweeps work best in my sand ground. They are not the best in the clay loam farm I have, best thing there are narrow sweeps of 4 inches at the widest and a whole lot of them on an S tine, I think, I just don't have anything set up for that farm...yet.
