A Couple CA questions
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Topic: A Couple CA questions
    Posted: 29 May 2025 at 4:59am
Hey everyone. I have a couple questions about my 1955 CA I don't have the serial number handy but can provide if needed.
I just got a new battery box. What decals should be on it to make it accurate and original.
And I've always wondered....I have seen some came with rad shutters, some with a canvas winter front cover. What determined if your tractor had those? Different run in build date? Different year of manufacture?
My CA has a regular thermostat, so would it still have come with shutters or a winter front?
And lastly, were the steering wheels all black or should I paint the spokes orange like what is on mine now?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 3:42pm
CAs did not have any decals on the battery box.  The hydraulic setting decal is located on the left fender.
No CAs ever came with a canvas front cover - they all had shutters regardless of the year it was built.  Yes, thermostats were still used even though they have shutters.
My steering wheel is all black.  An all original 1955 CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 3:52pm
Surprisingly we still had to run our CA with the shutters partially closed even in the hot summer to keep it in the green zone. And that was while running a 6’ Woods belly mower. As said the decal is on the left fender.
Edited by AC720Man - 29 May 2025 at 3:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:09pm
Okay, thanks. So mine is correct. It has a decal on battery box but it has something to do with the battery (too tired to run out and see exactly what it says.) And my hydraulic/traction booster decal is on the left fender.
I have the hole for the shutter crank, but sadly they are gone. And as you said AC720Man, mine always runs cold too and it has a new thermostat and water pump in it.
Thanks Dseries4, I'll leave my new steering wheel all black then. The one on my tractor has orange spokes.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:19pm
I saw that it should go on the left fender, but my fenders were too rust pitted.  I didn't bother to clean that up when I painted.  I did try to clean some of it up on the hood/cowling.  Instead, I put the pump decal on the right side of the (new) battery box (I think other tractors had it there).  If I had more time to pretty the tin up, I'd worry more about decal placement.  One of them was for the oil filter.  Wouldn't make much sense to put it on the oil filter since its not AC and has other writing on it, so I put it on the hood between the filter and the gas tank.  I would have liked to keep it as original as possible, but it was not to be in selective cases.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:28pm
WD had the decal on the battery box. You can find shutters for sale. Post in the classified section and maybe you will get some hits. To keep a healthy engine you should get one otherwise it will build up condensation because it is not running hot enough.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:13am
I've got CA shutters if you want/need a set.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:27pm
I have 2 CA's and neither one has shutters????
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:46pm
I would be curious to hear what kind of temp your gauge shows without shutters? I bet our shutters are half way closed to keep it in the green. Just flushed the radiator last year and added new coolant during an oil change. In Va we have temps in the 90’s during the summer.
Jim I see your in KY, we are visiting for our nephews wedding and went to the ARK Encounter today while here. Very impressive exhibit. Have enjoyed seeing horse country and the beautiful farms. Staying in Harrodsburg.
Edited by AC720Man - Yesterday at 2:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:45pm
I'll let you know July first. My parade season starts then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:18pm
My CA stayed in the low "normal" range during its first workout.  Shutters were left open.  Did take a little extra long to get up to temperature, but my thermostat is about 10 degrees below the proper value.
1952 CA13092
