A/C 6060 ether can |
chefiam1 ![]() Bronze Level ![]() ![]() Joined: 20 Sep 2019 Location: centerville,pa Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Oct 2022 at 3:19pm |
Hello, can someone tell me if there is a short ether can that
goes into ether holder . cannot seem to find short can that fits inside holder? Thanks chef
Darb210 ![]() Orange Level ![]() ![]() Joined: 10 Jan 2011 Location: Ohio Points: 845 |
NAPA # 7200
thanks, chef
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5139 |
Just curious, does your factory block heater work?
only AC orange ![]() Silver Level Access ![]() Joined: 06 Dec 2014 Location: Eastern Indiana Points: 496 |
Most ag supply stores have short and tall ether cans. The block heater on my 6060 is GREAT! In about 15 minutes time, it will start easily!
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5064 |
AGCO Ether is good stuff as well, and available in the short cans. 79014649
Ed, glad you chimed in on this. Isn’t either harmful to the pump? Engine gets addictive to it? Dad used either in the beginning when he bought the 6060 new because it didn’t come with a block heater. I think that became standard later on. It was an option in 1981. He noticed it became harder to start a few years later so he installed a factory block heater. Problem solved, plug it in 30 minutes before use and she is good to go.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8499 |
I could be wrong but I don't believe ether is a problem on it's own. It is the way it it administered that becomes a problem. Just enough to get it lit,not a bath.
carefully administered it's no problem. When someone over does it and the engine rattles like crazy, or locks up from the ether is when it's a problem. Fine mist is what we use to get the pulling tractor going, it's not that the compression is really low, it's the fuel we use is cold blooded. At no point would ether hurt the pump though. Overdosing ether knocks the ring lands off the pistons. My puller pops right off on vp torq dx performance diesel fuel.
Thanks for the clarification, just seamed like it became harder to start after a few years of winter time starts. The 433 isn’t a easy starting engine below 55 degrees.
right now it's 34 Deg here and my F2 (14:1) is sitting in a corn field. I'll finish that field starting in an hour. I would never get it started without the ether injector.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 2978 |
It most likely got harder to start because it became used and had higher hours on it. A new diesel with higher compression starts better
