80s and 82s side mount sickle mower ???? |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2259 |
Topic: 80s and 82s side mount sickle mower ????Posted: 30 May 2017 at 10:12pm |
What is the difference between the 80s and 82s side mount sickle mower ?
Thanks in advance
Mikez
Posted: 30 May 2017 at 10:15pm |
I'm not exactly sure. I think the 80 is the cable lift and 82 is hyd lift
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Posted: 30 May 2017 at 10:46pm |
80s has the big frame underneath and takes a little effort to mount or dismiuntwhile the 82s has a cast piece that bolts to side of frame rail and can be hitched and unhitched in 10 minutes.
Mikez
Posted: 30 May 2017 at 10:50pm |
Oh yes forgot that. Darn I knew that to. Thanks Michael
Macon Rounds
Posted: 30 May 2017 at 11:30pm |
Thanks
So if i understand correctly, all the twin wheel drive and gear box and sickle components are all the same ? Just the mounting is different? |
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Posted: 31 May 2017 at 12:16am |
For the most part yes. Other than the mounting hardware Allis added bearings to the pivot points on the gear box. |
Thanks & God Bless
Dennis |
Macon Rounds
Posted: 31 May 2017 at 12:31am |
Ok GREAT !!!! Thanks for the info.
Brian G. NY
Posted: 31 May 2017 at 3:31pm |
82S And, the box enclosing the gear box is made of heavier materialAnd, the cut bar is made of much thcker material so it doesn't bend in the middle. And, this mower is fitted with it's own hydraulic ram which (when set up properly) will lift the cut bar to 90 deg vertical.
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 01 Jun 2017 at 7:18am |
The 82 twin wheel head is supported by roller bearings. The 80 is cast on cast with a grease fitting.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3134 |
Posted: 01 Jun 2017 at 7:57am |
The 80 and 82 whole gearbox assemblies won't directly inter change,and the arms,cross arms etc won't interchange unless everything is used.
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Posted: 01 Jun 2017 at 8:19pm |
We have both an 80S and 82S for mowers.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Macon Rounds
Posted: 02 Jun 2017 at 10:00am |
Thanks For all your help. See my classified add for 82 si parts wanted/needed.
