80s and 82s side mount sickle mower ????
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: 80s and 82s side mount sickle mower ????
    Posted: 30 May 2017 at 10:12pm
What is the difference between the 80s and 82s side mount sickle mower ?
Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 10:15pm
I'm not exactly sure. I think the 80 is the cable lift and 82 is hyd lift
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 10:46pm
80s has the big frame underneath and takes a little effort to mount or dismiuntwhile the 82s has a cast piece that bolts to side of frame rail and can be hitched and unhitched in 10 minutes.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 10:50pm
Oh yes forgot that. Darn I knew that to. Thanks Michael
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 11:30pm
Thanks
So if i understand correctly, all the twin wheel drive and gear box and sickle components are all the same ? Just the mounting is different?
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 12:16am
Originally posted by Macon Rounds Macon Rounds wrote:
Thanks
For the most part yes. Other than the mounting hardware Allis added bearings to the pivot points on the gear box.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 12:31am
Ok GREAT !!!! Thanks for the info.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 3:31pm
82S
And,  the box enclosing the gear box is made of heavier material
And,  the cut bar is made of much thcker material so it doesn't bend in the middle.
And,  this mower is fitted with it's own hydraulic ram which (when set up properly) will
         lift the cut bar to 90 deg vertical.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 7:18am
The 82 twin wheel head is supported by roller bearings. The 80 is cast on cast with a grease fitting.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 7:57am
The 80 and 82 whole gearbox assemblies won't directly inter change,and the arms,cross arms etc won't interchange unless everything is used.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 8:19pm
We have both an 80S and 82S for mowers.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 10:00am
Thanks For all your help. See my classified add for 82 si parts wanted/needed.
