80-R3 mower
Joe in Manty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe in Manty Quote  Post ReplyReply Direct Link To This Post Topic: 80-R3 mower
    Posted: 25 Oct 2016 at 10:42pm
I am looking for some insight on my mower. It is my second season with it and am always learning about its operation. I have one issue though that has been bothering me.
In the manual, they talk about the transport rod. I see how it is used when it is holding up the sickle bar but it doesn't say what to do with it when in use. The previous owner had it wired to the inner shoe lift rod and it bounces around sometimes rubbing on the drive belt. Most of the pictures in the manual show it removed. Am I to remove it?
The hook on the rod is facing forward on mine but the picture in the manual shows it to the rear. Is either position preferred? The PO rebuilt a lot of the unit and he may have put this rod on wrong.
Any guidance with this helpful.
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 5:04am
I mounted  mine, from a hole in the foot rest to one of the cultivator mounting bolts, on the left side of the tractor...
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 5:34am
Same problem here with an 80R. I store the rod beside the clutch rod on a WD-45.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 6:20am
Calvin
On an 80R the long Rod mounts along the L/H channel frame of the Mower.
 The hook end goes towards front of tractor, hooks over the end.
The threaded 'J' goes through a bracket welded to the rear end.
Then install the 'wing' nut.
Gary
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 10:01am
 I simply hang the rod on the fence where I start cutting and put it back on when I'm done.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:58am
I would lay it on the ground and forget where I laid it down .Hang on the fence sounds better
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 8:50pm
     Yeah, what Gary said. Hooks right up.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 1:06am
I used to lay them on the ground next to the jug of ice water when I was using an AC mower,I'm not going to forget where the ice
water is located.
