80r sickle mower mount wanted for CA
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: 80r sickle mower mount wanted for CA
    Posted: 05 Sep 2016 at 9:11am
Does anyone have a 80r sickle mower mount to fit a CA
Or would Anyone be able to post pictures of what one looks like I think my uncle had the mount for a d14
Because it's to wide where it's suppose to attach underneath and the holes to connect the pins are wrong
If someone does have one could I get pictures of the sides and what the measurements are
~AMP~
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:40am
I got the prints from Agco a few years ago. I will see if I can find them for you.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 4:34pm
I seen in a search on here there was a post about these mowers showing the three different types
For the ca and all the d series
But I can't get it into the correct form to show what I found
~AMP~
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 7:26pm
is this a snap coupler CA? or a Pin Hitch?
Do you know if the same mount is used for a D10 or D12?
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:49pm
This help?  CA, D10/D12 Should be the same.
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 8:11am
Matt the one orange reborn posted looks like the one my uncles after
He was going to modify the one for a d 14
But before he cuts it up we though we should see if someone might have one on here like the one pictured above
Thanks all for the help
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 10:40am
 In found the prints as well as one of the attaching plates (pictured below).
For some reason I have only one attaching plate. I thought there was a pair so I will keep looking.
  I looked for this assy for a long time and could not find one. So a friend called AGCO and got the prints for me. Once I received the prints I drew up the parts using AutoCAD and had the parts laser cut and formed. Once I had the parts I found a mounting bracket for a 80S mower. I cut off the attaching plates and welded on the new ones for the "CA". You can use any of the mounting brackets as they are all the same, the attaching plates are the only difference.
 What I have to offer is 1 attaching plate, 1 set of prints and the AutoCAD drawings. If your interested send me a PM.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 1:28pm
Yes I'm interested how much Are you thinking for everything
My number is 507-339-0175 Andy
~AMP~
