8070 won't start after overhaul.
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Topic: 8070 won't start after overhaul.
    Posted: 13 Jul 2012 at 2:50pm
8070 was just overhauled. pump and injectors were not touched.It will fire and die on ether. have good fuel flow to injectors and plenty of exhaust smoke. going to check timing next. I didn't work on this myself. Just trying to help someone out.
Cen IA John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cen IA John Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2012 at 3:33pm
Same thing happened many years ago when a Brand X dealer overhauled my 8030 for me to purchase it. Your pump is 180 degrees out of time. Do a 360 turn on the crank and realign the timing marks. Brand X dealer had never heard of such a thing as 180 degrees out or how to fix it. My diesel school and being an AC fan since the D series has kept me up on the GREAT ORANGE tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2012 at 3:49pm
we had thought of that and we were retiming it as you were typing. Just fired it up after the 180 turn and it fired right up. Thanks for you help.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2012 at 9:59am
the model 100 confuses lots of people since it runs at engine speed at the drive, so timing mark can either refer to 1 or 6. Most other pumps run 1/2 engine speed so when timing mark lines up, it is on #1 compression when everything is right.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2012 at 1:26pm
Ed, I have always wondered if the 6060/6070/6080 series injection pump ran at 100% crankshaft speed as well?  Or is it 50% of the crankshaft speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2012 at 10:30pm
1/2 engine speed. Those tractors use a DB2 roosa pump.
