8070 problem |
Slaughter ![]() Bronze Level ![]() Joined: 16 Oct 2010 Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Oct 2010 at 8:08pm |
I have a 8070 with 5000 hrs on it. I haave been using it on the grain cart this fall . All fall it has been plutting out a lot of smoke and has lost power. It has a new turbo and the pump and injectors rebuilt in the last year. Starts good but has no low end power Any help would be helpful.
Troy ![]() Silver Level ![]() Joined: 11 Oct 2009 Location: MN Points: 75 |
if it is black smoke it is not getting enough air check for a boost pressure leak at manifold or crossover tube, do you here a whistle at all? also check for restricted air flow maybe air cleaner . if it is white smoke it is unburned fuel as maybe injector tip blown off or timing or anything to do with low compression on a cylinder, what color is the smoke?
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7497 |
Is the air filter clean?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21855 |
Blown intake gasket between the intercooler and the cylinder head....fails just above the starter usually. |
ACB110 ![]() Bronze Level ![]() Joined: 21 Apr 2010 Location: Blairstown Points: 6 |
Just replaced our fuel injector pump on our 8070 the advance/retard timing mech. went bad only 1700 hrs. on it.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5095 |
As Dr says, or check for any plugs in manifold that may have fallen out. Have seen this several times. Put a boost gauge in the manifold and check it. This tractor sounds like it isn't getting boost. Then you need to find out where it is escaping to. good luck, Ed.
