8070 oil cooler
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8070 oil cooler
    Posted: 22 Dec 2015 at 11:31am
I have the oil cooler off my 8070. The service manual says to take the cooling tube assembly out. Before i start, will it come out with a little tap on one end?
Thanks Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 12:17pm
You need to whittle down a 4" x 4" block of wood and put it up against the cooler core to drive it out of the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 12:31pm
Thanks for the information! Will do.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:24pm
check the front side tubes carefully, if a water pump ceramic seal has ever broke it will stick in one of the holes and sometimes vibrate and wear a hole or a thin spot where the tube is soldered to the plate. When you take it apart it, the ceramic piece, may fall in the front housing un noticed. Make sure the weep holes in the housing are open and not clogged with paint or crud.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:26pm
When you reassemble, make sure the orings go the right place. Two are made to seal oil the other two to seal antifreeze.  You will also notice a price difference.   MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 7:20am
And make sure the dealer just doesn't hand you all the o-rings in one unmarked bag. They used to be colored different but aren't anymore. I took them all back and got new ones, which I had to wait for, in the original package with part numbers. Parts man, who was apologetic about it, was otherwise clueless. All parts guys should be a farmer first, then a mechanic before becoming a parts man.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 11:26am
They came in different bags with the different numbers on them. Your rite, all the same color, but a big difference in price in the 2. Thanks for all the help.
Randy
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 6:43pm
What is the difference in material of oil orings and antifreeze orings?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 9:36pm
The material they are made of.  MACK
