8070 experimental |
Page <123> |
| Author | |||
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 04 Aug 2016 at 9:03pm |
I bailed out the end of 1984 and understood that was stopped by Deutz before it was prototyped. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
| Sponsored Links | |||
LB0442
Posted: 04 Aug 2016 at 9:04pm |
Here is a link to the machinery pete video.
In the video the shop foreman talks about the tractors and speaking of the 8070 experimental he said they built it with a bunch of parts they got from AC, and they moved the front axle 10" forward. From that I guess it was more of an experiment on their part, not a prototype unit.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2434 |
Posted: 04 Aug 2016 at 9:18pm |
Head scratcher for sure. I have never seen an 8000 series with factory 42 inch wheels, so those cast rears may be right? The serial number and age of the tractor don't make it a late production tractor and yet it looks like it has the wide planetary gears plus the fill tube for the rear end is moved. I don't see any advantage to that? The front axle is certainly different, Hyd. cylinder with a tapered ball joint,they needed that, king pin caps, they needed that also,and even the tie rod is different,upside down. Another minor thing is that the fuel tank breather hose clamps are a worm gear design, I don't think that is correct. I will say that it does have the late Allis frame
ty paint job. That was embarrassing back in the day.
Edited by Lynn Marshall - 04 Aug 2016 at 9:21pm |
Joe Graunke
Joined: 14 Sep 2009 Location: Clayton WI Points: 659 |
Posted: 04 Aug 2016 at 9:26pm |
The rear end has 8095-4 stamped in it.
Joe |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2317 |
Posted: 04 Aug 2016 at 9:36pm |
Ihave a neighbor with 8070 with 42 in duals I believe are factory original.
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 04 Aug 2016 at 9:43pm |
Why does it say in the sale bill. It's serial number 16xx 8070 ? |
ILGLEANER
Posted: 04 Aug 2016 at 9:44pm |
I have a 8070 with 42" cast centers. The wide planataries would match a 1600 serial number
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1984 |
Posted: 04 Aug 2016 at 9:46pm |
There is a picture of the shift levers showing it to just be the two speed. I have often wondered if they could have put a third range in them and put clutch packs on the three ranges how it would have worked for a full 18 speed powershift. Im thinking it would be a neck snapper but I wouldnt know for sure. Hate to say it but IH had a great transmission with the 18 speed countershaft powershift. Still being used today in blue and red tractors.
Lynn Marshall
Posted: 04 Aug 2016 at 10:14pm |
Aren't the wide planetaries only used on the early 8070 two wheel drives?
427435
Posted: 04 Aug 2016 at 10:39pm |
The 3-speed range wasn't going to be power shiftable (barely room to get the 3rd range in let alone clutch packs). It would have been shifted similar to the way the 2-speed range was shifted. The middle range would have gone from about 3.5 mph to 12 mph or so. Thus, you wouldn't have had to do any clutch shifting once in the field as all normal field speeds would have been in that one range. |
Mark
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8731 |
Posted: 04 Aug 2016 at 10:45pm |
Yes.The FWA's used the 8050 rears and ser#2662 they went to narrow (8050) rears on 2WD 8070's. Mines 30XX 2WD with narrow finals.Norm's book says testing proved they didn't need the wide ones but maybe the truth is they used up all the leftover 7080 finals? Edited by SteveM C/IL - 04 Aug 2016 at 10:47pm |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3545 |
Posted: 04 Aug 2016 at 10:49pm |
Joe Heofle (SP?) who I think was project engineer in the ps toyed with the idea of putting a pd in front of the power shift. ... never made it much more off the table napkin sketch ... that would have been a side shift of the ps lever in each 6 gears....
427435
Posted: 04 Aug 2016 at 11:11pm |
Putting either tranny in front of the other would have killed the 2nd tranny due to the large increase in torque being delivered. |
Mark
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 05 Aug 2016 at 4:55am |
If you want to know about the 8095`s talk to Everitt Hunley.
"Burgie"
Lonn
Posted: 05 Aug 2016 at 7:41am |
Wink I am a Russian Bot |
JimIA
Posted: 05 Aug 2016 at 8:13am |
Yeah, I knew it was going to be a manual shift, that's just my "speculating" you could say. Like many others on here I keep wondering on what could have been. Thanks again for all the work you did on these fine tractors Mark. Jim |
427435
Posted: 05 Aug 2016 at 9:31am |
I've posted this before, but as a reminder for what an 8095/9025 really looked like:
![]() Those are 20.8-42 rear tires. The test people referred to the tractor as Big Foot!!. ![]() |
Mark
427435
Posted: 05 Aug 2016 at 9:37am |
Anything is possible (given enough time and money, an 8070 could be put on the moon). However, some things aren't practical. The PS was already at it's limits for torque capability in the 8070. ![]() |
Mark
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2879 |
Posted: 05 Aug 2016 at 2:19pm |
Isn't he dead? If he ain't dead he certainly doesn't answer his phone or return calls. |
ILGLEANER
Posted: 05 Aug 2016 at 9:28pm |
He is a snowbird now. Goes to Florida for the winter |
Krazy Karl
Posted: 05 Aug 2016 at 9:32pm |
It's something they put together. Check out machinery pete on you tune allis collection. The hire man talks about most of the pieces
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 05 Aug 2016 at 10:28pm |
Yeah, I watched the video, and 'Ol Pete, kinda acts like a used car salesman during that specific conversation. He keeps repeating the "experimental" when the farm manager clearly states its just a Hodge Podge of parts they had around, or bought from Allis. Nothing truly experimental about it. Never assembled by Allis, never tested by Allis, never known to Allis per se. Maybe it has one of the 8095 rear ends in it, maybe it doesn't. Heck, we have hundreds of 70xx series pieces laying around, maybe I could "Put one together" and call it an experimental also, and stir up a big internet buzz!!
Still in use:
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1167 |
Posted: 05 Aug 2016 at 10:47pm |
The front axle and the back wheels is the experimental parts from the 8095 and maybe the rear differential but rest is pieces put together. |
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
427435
Posted: 05 Aug 2016 at 11:10pm |
The back wheels weren't experimental. They were being released for the 8000 series in general. |
Mark
tbran
Posted: 05 Aug 2016 at 11:16pm |
my post didn't come out right, I meant Joe mentioned putting a PD two speed clutch and reduction gear set as a 'splitter' input to the power shift. Not the whole tranny. Enough room w/o much stretch.
acben20
Posted: 06 Aug 2016 at 12:32am |
I searched the sige front axle in Europe where I buy tractors and found the same axle this 8095 replica has on it.. Sige is a very common fwd axle over the pond and no they didn't just make a axle for Allis Chalmers.. Allis bought the axles from them over seas for the 8000 series.. It is avalible for 2800 euro.. Used. My guess is they found a axle and got it to fit.. The other 8095 hunnly bros have is totally different yet then this one on the auction. I just hope some one doesn't pay big money for what in my eyes is a replica!! If they do I will have to ship over a few axles and get building.. Lol just my 2 cents
ac45
Posted: 06 Aug 2016 at 1:49am |
Everett Huntley would be the one to clear up what's what . If I remember correctly the 8095 rear end is the 8070 2wd rear end big axles coupled to the power director of one of the big 4wds ( maybe the 4w305). The frame on the 8095 is longer and there is an extra sheet metal piece in front of the cab to account for this. I'm not sure on the front axle but it sounds as if you could build the 8095 drive train from existing parts.
Burgie
Posted: 06 Aug 2016 at 4:13am |
Try Everitt at 812-595-1295.
"Burgie"
JimIA
Posted: 06 Aug 2016 at 8:00am |
I wouldn't call it a replica either. A replica would be a totally made up machine. This does have the serial number. Not waying that makes it worth more. Watch the Machinery Pete video, the guy says it basically came in pile and they put it together with what they had. He also mentions moving the front axle ahead. People are going to pay what they want to pay. Remember that "model H" a few years ago? Case and point. |
Lynn Marshall
Posted: 06 Aug 2016 at 8:02am |
Anyone have any information on the Komatsu engine that was to be used in the 8095? Was it a new model or was it being used in other applications?
Page <123> |
