8070 and 3000 plow |
Page <12 |
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 603 |
I hadnt thought about the dampener but it is my understanding on 7080s and 8070s is a fluid dampener and they dont go bad
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
They do.
Keep in mind these tractors are 40-50 years old... |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Gleanermanl2 ![]() Bronze Level ![]() ![]() Joined: 29 Sep 2013 Location: Kansas Points: 21 |
Im not sure what sound you are hearing with your engine or what rpm etc but the ambac injection pump leaves a bit to be desired. If its never been rebuilt its probably time. The governor inside them is very toutchy. My 8070 with the ambac pump had a strange sound i noticed when roading it at around 1600-2000 rpm. the governor would quiver and very quickly fuel and defuel causing some black puffs from the exhaust and a really strange sound from the cab. It was quick. probably 3-5 times per second it sounded almost like a misfire on one cylinder. turns out it was the injection pump governor quivering. Just a thought. Hope it helps
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8612 |
They are silicone filled but there is nothing that says they can't go bad. Have seen pics of cut open ones that the silicon was "dried" out.
Does anybody know where to get a dampner
1984 80780
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 812 |
Big help. Thanks
1984 80780
Page <12 |
