8050 torque limiter issue or tranny?
4oranges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Topic: 8050 torque limiter issue or tranny?
    Posted: 03 May 2021 at 1:56pm
I've got a 8050 2wd, power shift. Just had it split about 8 hours ago.
I put in a new torque limiter, bellview washer, had the flywheel machined, and checked size on all the spacer. Plus I did the engine plate gaskets and the transmission seal. Changed all fluids and filters, cleaned the screen as well.
I followed the instructions in the service manual for all torque specs and break in. I had no issues disking for the first few hours but now with the digger on it is acting up. Much like it's slipping, the engine will idle up a bit while my forward momentum slows, takes a few seconds than grabs again.
I tried slamming on the brakes to check if I had hydraulic when I stopped but I kill it every time I hit the brakes and I have power steering the whole time. I had no transmission issues pre torque limiter job. I've checked the transmitter fluid level and it's a bit over full of anything.
Any ideas?
It also acts this way when I shift to 5 or 6 high on the road. Not sure what to look at next
Edited by 4oranges - 05 May 2021 at 5:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 2:08pm
When saying followed instructions,does that include burnishing the T/L after install? Sounds like it slips and then grabs. When it slips is the time to jam the brakes and kill it. It's all in the book. I am not a professional mechanic. Doc ,Mack, Lynn will have better answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 2:23pm
Steve, when I say followed the instructions that is what I mean. I ran it wide open in high 3 and held the brakes till she died. Did it 8 times and never got it to skip.
When it has happened in the field I followed the same procedure the first 10 times it happened.
Once it kept happening I used the brakes to try prove it was the T/L but I always have hydraulic power and can easily kill the tractor, wide open throttle when I try to prove it's the limiter
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 2:36pm
That's what I thought you meant but hard to decide in print sometimes so it is a head scratcher now. Above my paygrade. Hope your new rear main hasn't started leaking oiling the T/L?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 5:38pm
Park the tractor overnight with the nose downhill a bit and see if there is ANY oil that drips out of the bottom of the bellhousing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 6:04pm
I'll try that and see what happens. The housing looks dry, and I did put the shield back in when I reassembled it
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 8:56pm
Did you reseal the PD while motor was out? If not that is a good time to do it. Are you sure you put Bellville washer on the right direction?         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 10:01pm
I think it's a power shift MACK.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 10:58pm
Is the trans lube light above 1800 workng if it is a PS ?  If so do the clutch pac test of lower the rpm til the light comes on - then rev up to just put it out - then shift r- 1-6 - light should come on then out same time and go out each shift.  Lube light on in any certain gear indicates issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 10:40am
Well morning update. I parked on a hill last night and there was no oil this morning, dry as a popcorn fart.
Then (after it warmed up) I did a clutch pack test and everything was good there.
I took it out with the 18' disk to mess around a bit and I noticed that not only does it act really soft when I shift gears but when Im pulling and go to lift the disk the tractor does it's "slipping" (for lack of a better term) thing when I use the hydraulics. Now that's not the only time but it sure happens on command when I do that.
Is it possible that the supply pump has issues?
I did all filters and drained/filled the tranny with new fluid when I split it (Including cleaning the suction screen)
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 11:30am
This probably wont help you, but I did one about 8 or 9 years ago in an 8030.  It would sometimes slip after the first year, but not always when I shifted into high PD.  It got so bad last year it would slip when I would drop to low PD when pulling hard, so I put a new TL in it last month.  This one seated up right away, the other one took 6 or 7 slips before it stalled the engine out, I think the first one was never right...but that is justmy gut feeling.
Where is the screen in the hydraulic system???
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 9:41pm
You don't say you put in a new pressure plate. All three have to be put in together. One old piece spoils the whole batch.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 2:04pm
I wanted to say your wrong mack because the book says it's fine to reuse the plate if it's true. I had it checked and reused it. After a bunch of messing around with checking pressures and everything looking ok I took it out and started messing with it in the field again and then I got the TL to slip. No idea why I couldn't get it to slip earlier.
I assume once it's slipping I need to split it and do the whole works over again with all 3 new pieces correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 3:55pm
Oh Id never say Mack was wrong on Allis Chalmers !!!!
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 5:15pm
I have re used the plate only a few times.  All except once those TL failed prematurely (I feel), and the one that did not fail, was one I had machined and I also machined down the spacer pieces to give me the same dimensions as all original assembly would have.
The problem with these tractors, is they are all 35+ years old, and we most likely never bought them new, and we have no history of who worked on what or how they repaired them previous to us.  So all new parts mean its as good as new, in my opinion...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 9:00pm
I have tried using old pressure plate with no success. Turned one over for new surface, it busted after a few hours.             MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 11:46am
service manuals are written in a way they want you to follow in the event of a warranty repair. Of course, they would not want to pay for a part that is a year old and within spec. Now 40 years later, things are a lot different.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 8:28pm
If you are putting used parts in a tl you have shot your self in the foot ,yes it is a grand but you are done with it
